360 and 390 Horsepower and torque?
So could you run a 390 crank with 360 rods and pistons (in a 74 360 truck block) and bump the compression up to the 10s?
1.892 + 6.542 + 1.778 = 10.21. (1/2 stroke, plus rod, plus compression height)
Deck is 10.17.
If you have a different length on the rods or compression height, add it up again.
390 crank and rods, 360 pistons will give you about 9.5. It seems 360 pistons are the same or approx the same spec as 390 2bbl regular fuel pistons from '66-'70 or so car engines.
So if you want 10's, you can get car pistons from the '60s that will work, or other aftermarket pistons that will work. It also depends on your heads cc size.
My 65' galaxie with a 390 came factory with 10.2:1 compression. Haven't had it apart and its still running good at 46 years old so I don't have any part numbers or measurements on the internals for you. It has the c4ae 6090g heads and factory 4v intake and came with a automate 4100 carb with 1.12 venturies which translates to right about 600 cfm. If you can find one of these or the parts you would be set. 300 hp and 427 ft pounds from the factory.
I don't think that will even work at all.
Deck is 10.17.
Deck is 10.17.
Actually I think 9.5 is about all I want... since the low compression 360 probably wouldnt like boost too much.... lol
360 with 428 heads
360 with 428 heads what do you think the hp also are the motor mounts the same as a 390 block?
davelong667
30
01-29-2017 11:36 PM
Tylersgrave
03-15-2011 05:55 PM
Blown 331
12-24-2009 04:57 PM
lilpig88
05-30-2003 07:18 PM
