installing the sky manufacturing front reversal?
#61
#62
#63
#65
#67
either set of springs off a superduty or our year from a 350 will work as far as i know. I would keep the blocks near by just in case you need a little more lift to make it look right. just remember with the flip kit on there if you put the blocks back on they will need to be turned the opposite way so they are facing the rear of the truck. This is because the flip kit lowers the rear mounting position of the spring a good bit and your rear axle angle has changed
#68
And actually if I read their site right before, they actually recommend using lift blocks with their setup in place of the stock blocks under the spring, and as coalroller points out, installed in reverse. They say that the rear shackle flip moves the differential forward approximately an inch. That's an issue for me as 1" would likely stuff my driveshaft to fully compressed - big reason I still have stock shackles and lift blocks yet on mine.
#69
Ok, fixin to go to the wreckin yard, not the truck, me. I need to find some front leafsprings. You say 99-04 F250 will fit and give it lift? Does it have to be off a F250? I expect it has to be off a 4x4, i think the 2x's are coils on the front? right? Help me here Oreo, your the genius!
I am not so sure what you are trying to do is going to worth with the TTB. Good luck
#70
Hey guys, im doin the same feveral sky manu the 5" kit. Onto a 94 f250. Had the ttb 50 and i swapped in the d60 kingpin. Im doing the 5" kit, with 6" lift springs from procomp 22610 for a 99-02 i think f250, same eye to eye length as stock so ya. Anyway im havin to do my own thing for frame mods, anyway i got it all together, tacked together, go to lift the truck by the axle and the spring shackle seings all the wY back to the frame and bottoms out. Whats that about? It seems theres not enough travel, anyhelp is appreciated. I posted an ad about this in the regular forum for my truck also
#71
Assistance needed!
[/QUOTE]
Hello sir,
i have ran into the same problem as you and I really need these fab pieces . I'm stuck on this project and could REALLY use your help. Please let me know if you would be interested in remaking these frame inserts. I would really appreciate.
Thanks
Austin
Hello sir,
Thanks
Austin
#72
Hello sir,
Thanks
Austin[/QUOTE]
Off Road Unlimited makes them for their RSK
Thanks
Austin[/QUOTE]
#74
Jim40216
10-03-2016 01:23 PM
