Looking for Headlamp Retaining Ring
Old Feb 16, 2011 | 01:15 AM
TheThickster's Avatar
TheThickster
Anyone used this retaining ring from Help!?
Dorman Products - 42408
The tiny weld broke on one of mine and wondered if anyone knew if it was compatible with our ford trucks.
Old Feb 16, 2011 | 11:03 AM
jmf66's Avatar
jmf66
I've not used it, but it looks like it'll will work with the 7" bulb. Another source would be a vintage Mustang parts vendor, but if you can get it local... it would save shipping cost.
Old Feb 16, 2011 | 11:51 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by TheThickster
Anyone used this retaining ring from Help!? Dorman Products - 42408
Universal "fitz-all." It might work, but it does not match the originals.
EZ to find in junkyards...
1941/79 FoMoCo Passenger Cars, 1941/86 Trucks, 1966/79 Bronco's & 1961/77 Econolines, all with single round headlamps, used a similar retainer.
Originally: 11A-13015-A / Replaced by: C9DZ-13015-A in 1969, then by D3TZ-13015-A in 1973..
The original (1941/68) had a feature where each bracket had a hole in a figure 8 pattern. It could be put on, then twisted to install it. The screws did not need to be removed.
The replacement doesn't have this feature, just a single round hole in each bracket (similar to the Dorman retainer ring). The screws have to be removed to install it.
The Ford types have three brackets spaced equally apart (for example, like a Mercedes-Benz hood ornament). This "fitz-all" is the same style as D3TZ-13015-A, but has more brackets.
D3TZ-13015-A .. Headlamp Retainer Ring / Available from Ford.
MSRP: $28.53 // PARTSGUYED.COM price: $20.54.
Want a NOS "original?" 11A-13015-A =
HAVEN FORD in Haven KS has ONE = 620-465-2252.
JST AUTOMOTIVE in Lebanon TN has ONE = 615-443-3086.
LINCOLN OLD PARTS STORE in Clearwater FL has ONE = 727-445-7551.
CARPENTER NOS OBSOLETE PARTS in Concord NC has FOUR = 800-476-9653.
Old Feb 16, 2011 | 08:40 PM
TheThickster
thanks for the info you guys. ND +rep for the tons of info.
Old Feb 16, 2011 | 09:01 PM
Bill W's Avatar
Bill W
if you still need i have a few of them.
Old Feb 17, 2011 | 11:20 PM
William's Avatar
William
Headlight Ring
I'd try soldering the old one unless it has other issues. drill a small hole through the ring and tab. Stick in a piece of copper wire to hold it in place and give the solder something to (wick) on. Clean it all up with a file. IMHO!
Old Feb 18, 2011 | 01:10 AM
Jetcopterpilot's Avatar
Jetcopterpilot
If you get desperate
https://secure25.securewebsession.co...shop/index.htm
this shop usually has the retaining rings and this shop always has them NOS
1948-1986 Ford Trucks
fordboy300
39
Oct 6, 2021 11:21 AM
Bullitt390
May 1, 2014 01:52 PM
turbill
Sep 9, 2011 04:57 PM
Spaceman Spiff
1997 - 2003 F150
May 3, 2011 06:03 AM
