Removing pedal assy. '49 F-1
Old 02-15-2011, 01:08 PM
Fordman49F1's Avatar
Fordman49F1
Fordman49F1 is offline
Fordman49F1 is starting off with a positive reputation.
Never done this before, never seen much on it. If this has been covered, please let me know and I will kill this thread. Can anyone help me figure out how to remove my pedal assy? In particular, the clutch pedal. I am having a tab welded onto it for my clutch cable to allow enough travel to actually have a fully engaged clutch. Pretty exciting stuff! Do I need to remove the master cyl? I know I need to remove the floor pan parts and pedal pads...anything else?
Thanks!!!
Old 02-15-2011, 01:29 PM
tinman52
tinman52 is offline
Welder User
tinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputation
Pedal assy is bolted to the x member with 3 or 4 bolts....2 of em hold the master cyl on.
You should be able to leave the master cyl there, just tie it up or support it so it doesn't kink the lines.
It should drop right out once everything is disconnected. Not sure about removing the pedals from the brackets....
Old 02-15-2011, 01:49 PM
Fordman49F1
Ok...thanks for the advise. After doing some more homework I found it is best not to weld on the pedal mounts...so I intend to make a bracket. I will put some pics up once I get it done. Thanks!
Old 02-15-2011, 04:32 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
Old 02-15-2011, 04:58 PM
mtflat
mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
If you intend to remove them to assemble your bracket, you'll probably want to remove the floor pieces around the steering column/pedals.
The pedal pads just unscrew from the arms. Std right hand thread so crank on them ccw to remove.
Old 02-15-2011, 08:35 PM
eman92082's Avatar
eman92082
eman92082 is offline
eman92082 has a great reputation on FTE.eman92082 has a great reputation on FTE.eman92082 has a great reputation on FTE.eman92082 has a great reputation on FTE.eman92082 has a great reputation on FTE.eman92082 has a great reputation on FTE.
If you want to remove the pedals from the pedal shaft, there is a .25 diameter pin at the end where the zerk fitting is. Sometimes these assemblies get so gooped up, people don't know they are there.
Old 02-15-2011, 09:48 PM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
One of the parts trucks I bought some time ago had the clutch pedal removed. It kind of threw me off for a brief moment before I could figure out what was going on.
nothercrash
12-10-2011 07:36 PM
rcook56
10-12-2010 08:16 PM
Schmitty
09-23-2010 09:09 AM
1bikenerd
01-26-2010 08:36 PM
1982fordf100
05-30-2007 08:46 PM
Quick Reply: Removing pedal assy. '49 F-1
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
