Where to get straight gas, no ethanol
If anybody's in the middle of Iowa, I saw a pump that looked like the 87 octane gas was ethanol free. The 89 and 93 were both labeled 10% ethanol, and the 87 wasn't. You've gotta pay for it though. The "Regular" unleaded was 10 cents per gallon more expensive than the 89 octane "Premium" unleaded. If anybody cares it was about 45 miles north of Waterloo on 218. Only place I've seen it, and it was the middle of nowhere. Literally, the gas station was the only thing at the exit.
Has anyone else seen ethanol free gas anywhere? Just curious.
I'm in southeast Nebraska, and the 89 octane is 10% ethanol. The 87 and 91 octane are ethanol free. It's like that at darn near every station around here.
I've been running 10% ethanol in my cars, trucks, lawnmowers, string trimmers (mixed with oil), chainsaws (mixed with oil) for the last 15+ years with no problems whatsoever. I'm just sayin'....
You know what's funny about that? One station I stopped at didn't even have the 89 octane choice. There were two labeled 87 and one labeled 93.
A lot of marinas have ethanol free gas as well; there are many old houseboats and cabin cruisers with gas engines that cannot run ethanol, it destroys the rubber fuel lines and gaskets.
My 2004 boat gets much better mpg on ethanol free premium gas than it does on the 87 octane 10% ethanol from the local gas stations. The only problem is gas at a marina is much higher per gallon than on the road, it can run as much as a dollar a gallon more.
Mike
Mike
Beware just because there is only one ethanol sticker on the pump that doesn't mean only one product has ethanol. It is only reqiures to be onthe pump not designate which product,it can be both. In northern Ia the 87 could have been 85"subgrade" with 10% ethanol. This is what BP sells as 87. I'm guessing that the station Craigoutdoors stopped at was a Caseys which does still offer regular 87 in most areas, and they generally price it higher but not always. Here the 87 regular is 10 cents less than ethanol blend.
Pat
This is super bp.4 ounce of gas to 1 ounce of water.The water was below the black line before i poured the fuel in and shook it. In 2 min. the ethanol joined the water at the bottom and raised the level way above the black line.Super 93 oct was worse than 87oct. They must use ethanol to raise the octane rating. This looks really bad for marine use!
Mike
I'm willing to bet that "ethanol 89" is just regular 87 with 10% ethanol added to it. The ethanol raises the octane.
As for boats that can't stand Ethanol, well, there's more to it than that. The rubber in marine applications has been rated for "alcohol" for a LONG time - like 2 decades or more. The boats that have problems after using Ethanol just have VERY dirty tanks, and the Ethanol starts to loosen the crud. Crud=BAD. Ethanol=LOOSE CRUD. LOOSE CRUD=BAD.
