Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Electrical Guides
- How to Replace Spark Plug Wires
Step by step instructions for do-it-yourself repairs
How to replace your 4.6L & 5.4L spark plugs
#526
#528
45 minutes to swap the plugs on a 5.4L, wow that's amazing. It was 45 minutes on my 78 Bronco, but not this 2004 Expedition. With a couple other things thrown it was 12.5 hours from start to being finished cleaning up. Now I had to go to the dealer, the parts store and the hardware store, make dinner for the kids etc, but crap this is insane. I twisted 2 extensions in half(1 amazingly was Snap-On), broke 1 elbow/swivel, broke a spark plug socket and broke 1 COP bolt. Took an hour to get the remainder of the COP bolt out, thank goodness it was on the #1 cylinder. The passenger side rear plug was a nightmare and where I broke all the tools.
I still can't believe how hard it was to get the plugs to break loose.
I miss the positive lock feel of normal plug wires being seated on plugs, that seems to be completely gone with the COP's.
I also spent over an hour trying to figure out why there was an uncapped/disconnected vacuum line. Turns out it's a vent line for the IWE. Sad thing is that I never noticed it before, but today it was laying on the steering column.
Every time I work on this thing I miss my 78 Bronco more. I love Ford trucks, been driving them for 22 years, but I can't say I much care for this one at least from a standpoint of working on it. Hey designers, the plugs belong on the side of the heads, please put them back there.
#529
#530
1st Irrelavent: I had my truck at the ford dealer yesterday for new treads (245/75R16 Goodyear wrangler duratracs )
2nd Relavent: While there I asked what labor only would cost to replace my plugs (not really having the time right now). I was specifically instructed not to take them in, after all possible damage "the shop guys" could do would cost anywhere from $600-3500. As of right now they are ***** deep in a 4.6L like mine and the owner is going to be out over $800.
So, Ill be making time soon to get this done. I just want to say thank you for opening up this thread. I tell ya a 400M in a 79 F50 with an engine bay that could fit 2 of me with the hood down is tons easier then this. Thanks, hope my input is useful.
Boomer
Boomer
#531
Thanks
--Paul Franz
#532
plugs in Ford 4.6 l
Paul F: my empathy ... dunno about a 4.6 l ford but I read all threads before starting , I went slow, vac, blow, vac, blow out all spark plug holes. The mechanic before me used silicone hence, easy to extract and reuse the boots It sounds like your boots (caps?) are cooked on, hence, plan on replacement and use silicone grease for next time. Use wobbly extension and swivels and piece of hose to extract and reimplant with antiseize. Don't move fuel rails. Don't drop small parts into the engine. Save old plugs and sequence and check for irregularities.
Ed P
Ed P
#533
Last night I fashioned a hose extension on a small hand pump oil squirt can and was able to jam the metal squirt point down beside the boot caps and then pumped solvent down in beside. I now have 6 of the 8 plugs replaced. Still have the two worst ones #4 and #8. Those are very hard to get hold of and now with solvent on them they are slick and really hard to grip. I'm trying to find pliers that will fit in such a small place to grip and wiggle the two back caps off. Of course, those are the two throwing the OBD codes. I did put silicone lube on the boot caps and anti-seize on the plug threads so in another 10 years it will be easier for someone. Hopefully not me.
#535
Failed getting #4 and #8 plug boots loose.
Well after the 2nd full day of trying everything I could think of to get the rear two cap boots off (#4 and #8) I phoned up Bellevue Auto Electric and have an appointment for the morning. They would have done it for $80 plus taxes. Had I known that, I wouldn't have wasted all that time. I can't recall admitting defeat before on any auto repair job but this was nasty. Sweat dripping off my brow onto my glasses didn't help. That fight sure made changing the oil and topping off air in the tires seem like a reward. I was pretty happy that after all the tugging and twisting there wasn't a new misfire problem. At least it runs smoothly even though it is throwing the misfire code. Probably right at the very end of plug life on #4 and #8.
Thanks for the tips guys.
--Paul Franz
--Paul Franz
#536
I know this is an old thread, but...
...maybe someone who can answer my question will see it or get an email about it. I'm changing the plugs and COPS on my 2001 F150 4.6L. I had to pull the fuel rail on the driver's side to get at #7. In the process, the #6 injector pulled from the manifold. There is what appears to be a ceramic 'cup' sitting in the bottom of the injector port. This 'cup' is cracked in half, and I'm guessing it needs to be replaced? If so, are these 'cups' available individually (where?) or do I have replace the injector? Thanks.<!-- google_ad_section_end --><!-- / message -->
#537
#538
Got all 8 plugs changed on my 2001 with a 5.4.....124k on them.........the cop on #8 has been replaced before.........put a bit of antiseize on the new motorcrafts, and the truck runs alot better......had a misfire on #2.....and when it didnt misfire, it ran ok.....but the new plugs made a difference.........probably will never put plugs in it again, I'll probably sell it before then.......maybe. took me about 2 2 1/2 hours all together.....take your time, and dont rush it......had to pull up the fuel rail on drivers side....to get #7 and #8.....maybe didnt need to, but I did.
#539
I think your talking about the plastic cap on the injector? It directs the flow of fuel. If it cracked like mine were it is not hard to fix but needs to be done. I went to my local parts store and got a injector kit (2 orings, the plastic divider peice and the cap for 5 bucks per injector. But they need to be done or you will just waste fuel with them not spraying properly. just pop of the old ones (not very easy but they do come of) and put on the new ones.
#540
2 Piece plugs on 2003 Ford F150 4.6l
I am kind of scared to try and replace my plugs and COP because i have heard horror stories about these being a 2 piece plug and that they can seperate very easy on trying to remove them. Is there any truth to this or is it a mechanic just trying to scare me enough so that i will pay him the big bucks to get the job? Could anyone please help out?
