Fuel Filter
Old 01-03-2012, 05:19 PM
cornfedp's Avatar
cornfedp
cornfedp is offline
Fuel Filter
Is there a trick to removing the fuel filter on my truck? I have never dealt with braided push on ones like mine has. I can get it to push farther on when I pull the retaining clip, but not off. Is it just being stubborn. Truck is in sig.
Old 01-03-2012, 05:52 PM
donniezyea's Avatar
donniezyea
donniezyea is offline
You are using the fuel line remover tool im sure right? (just checking) IF you are and its still being a pain spray some wd 40 in the spring area let soak then try again takes a few tries... I have had to cut the old filter between the body and the connector then your able to pull the lines down to work on. Last resort tho....
Good luck
Old 01-03-2012, 06:20 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
When using the disconnect tool, push the line toward the filter, then insert the tool, then pull.
Pushing the line on further toward the filter makes it easier to insert the tool and release the garter spring.
Old 01-03-2012, 07:26 PM
cornfedp's Avatar
cornfedp
cornfedp is offline
Thanks so much for the responses, I had no clue there was a tool to remove the lines. Hopefully it will be something you can rent from the local chain store. Or would that be what the plastic clips on the new filter are for. It is a Luber Finer filter.
Old 01-03-2012, 07:28 PM
White 97 xlt
There is not really any reason to rent them, the tool is less than 5 bucks.
Old 01-03-2012, 07:44 PM
White 97 xlt
Old 01-03-2012, 07:53 PM
donniezyea's Avatar
donniezyea
Originally Posted by White 97 xlt
Very nice!
Old 01-03-2012, 09:29 PM
cornfedp's Avatar
cornfedp
cornfedp is offline
Nice, that will take care of it then. Ill just swing bye tomorrow and pick me up that tool. I know ill use it again. Thanks again.
wraysp
06-12-2010 05:30 PM
tralfamadorian
06-19-2009 09:26 AM
mike L
09-28-2007 07:16 AM
k4uwc
1978 - 1996 Big Bronco
03-15-2004 05:24 AM
ford_dude
03-19-2000 01:45 AM
Quick Reply: Fuel Filter
