When I drive on a rough road, from the inside of my 2000 F250, I feel like there is something loose on my frame. I thought it was a loose shock, or one of the suspension pieces, I put it up on a rack, everything is tight(?)
Any suggestions?
sorry i cant help i have that problem too so pleas post problem when tou find i have a 2002 super duty 5.4 i replaced both upper /lower and inner tie rods seems every things is tight but cluncks like hell good luck
thanks for the tip . I must say thanks for your tech tip articals very helpful atleast to me anyway" if I could I would buy you a beer " thanks and good luck
