Engine Pics and accessory brackets
[quote=Mervy49;9988363]This is were I'm at with brackets on the engine. I'm designing and fabricating my own for the steering pump.
[quote]
Mervy looks nice! are you going to add a braket to tie the three long spacers together to make it easier to install.... shouldn't have any problem of the mount moving when it's tighten down 4 mounting bolts... Keep up the great work... BBF? What box/rack are you using?
[quote]
Moe,
I bought it off of Ebay, they are getting kind of pricey but sometimes you can find them that aren't listed right. If you search for them on ebay keep in mind that Packard and Oldsmobile also used them. I think they were used from roughly 1953 to 55 or so.
I think you can get a new repop from Speedway motors for less than $200
Thanks for the compliment on the valve covers....I sort of made them by combining the tops of mid 50's valve covers with later model valve covers.
Iwanaflattie,
Thanks for the compliment. I ended up using Ford blue on the engine because none of the local parts stores had Caddy blue in stock. Since its sitting in a Ford truck it all works out ok....lol
Bobby
Iwanaflattie,
Bobby
Moe,
Bobby
Bobby
[quote=Moe Craig;9988412][quote=Mervy49;9988363]This is were I'm at with brackets on the engine. I'm designing and fabricating my own for the steering pump.
I'm going to use long spacers similar to the factory method on the long bolts. I am presently rethinking this setup, I think I can come up with a better way yet. Saginaw pump and toy box.
Joe are you running a stock fan ( non electric) with a custom housing from the radiator? If so where did you get that made at??
Mike
