Posts that make you say "What the Hell?"
#1157
Will finally for my problem with my 2005 f250 no crank no start.
Will first of its was giving my cousin and jump off and after truck would not crank or turn over.it was throwing code engine data and trans temp error. It turned out to be a electrical connector that's behind the alternator. It was unlocked some how by itself. Crazy but glad the problem is fixed
Fire at Will.
#1159
Received 5,160 Likes
on
#1160
#1161
Where would you start?
"I'm new on here but I need help I got a 1991 f350 singal cab dually 2wd stripped chassie 10ft bed with the 7.5l aan a c4 aod automatic I believe in it and I bought it as a boom truck with no transmission in it and now I removed boom and utility body and all lines and gas tanks and it has the Dana 70 in the rear and I have a 94 Bronco that was wroled in an accident and all is good on it has a 351w and a aod trans I took them out and I want to put the ttb setup under my f350 but it's 5 lug so will it fit and could I change the axles in it to 8 lug and I have a 7.3 turbo and an s92 c6 transmission for it and I'm gonna put a flat bed on it and I'm not shure if the rear would work so same problem but bigger truck and the bronco is a d50 I believe"
#1162
Received 3,106 Likes
on
#1163
#1165
on
#1166
Maybe I'm too cynical:
.......... looking to purchase a new boat that I also want to have a trailer built for in case of a hurricane or something where I have to get it out and away from the beach in a hurry, I'll get all the OSOW permits, , anyways my point is, will an F-750 tractor pull that? Weight of the boat will be around 33,100 lbs loaded, and I don't know how much this big a trailer will add to it, but do you think I'd be able to do it with the biggest baddest truck ford's got going today?
Really, $100,000 for a truck and trailer and you haven't a clue what you're going to buy. You own a boat like that already and have no way to move it? You have explored none of the joys of boat ownership in that category? Just hit the lotto maybe? No time to think, just had to buy the boat? Balderdash I say.
#1167
#1168
#1169
Hope they never have to take it on the Interstate!
#1170
Hey guys I've been out of my 6.7 for about a year. It was deleted. I half heartedly tried selling the dpf on Craigslist with no luck. So now it's just taking up room and I want to get rid of it. Most of my junk goes to the land fill. But I don't want to do that with an exhaust if there is certain things inside it that shouldn't go to a land fill. What is the right thing to do?
Oh the irony...
