Rewiring the blower motor
Is there a way to redo the blower motor wiring with a relay like you can the headlights? My wiring harness is partially melted, and I'd like to run it all with relays so I don't have so many amps running through the dash wiring. I'm just no sure how you could get the different speeds.
I guess I don't really need anything other than high, b/c there are so many holes that it can't even keep up on high, lol. I wonder if using a relay would actually make it blow harder?
Not quite, A 5 prong Bosch relay would have one output (87a) that is always hot, that would run to the original switch likely with a new wire.
Output 87 on the relay is the "switched" portion.
When HI is toggled on the switch a new wire would run to from that particular output to terminal 85 on the relay which would engage the relay to send full battery voltage to the heater. So the new HI output from 85 would tie into the old heater wire coming from the old low-mid resistor.
Josh
Josh
No, that diagram is showing the relay supplying voltage to the switch, the actual heater switch works exactly the same as our trucks.
I'm sure there are a few ways to do it. With my idea, the voltage runs thru it for off-low-mid and then is activated for HI. And with the relay staying in the engine compartment, likely right there next to the battery you only have a couple feet of wire to the blower, full voltage.
Rather than the voltage coming from the solenoid/ battery thru the harness, thru the fuse block, up to the switch, down thru the resistor and then up thru the harness again back to the blower motor. It sucks just typing all that, let alone expecting the voltage to go all that way when the blower is right there.
Same ordeal with the headlights BTW.
Josh
Josh
AikenRooster
05-25-2018 08:24 PM
wjkrostek
09-17-2015 07:16 PM
LeeTribeRide
11-09-2013 04:10 PM
