rear main seal - wear flange
mates :
Purchased Ford 6.9/7.3 L rear main seal kit off eBay - instructions telll of removing wear sleeve - my rear crankshaft flange diameter is larger than seal - so I assume I have the wear flange installed - instructions tell to split this sleeve - yet my kit did not come with replacement sleeve - is this normal ? as new/replacement sleeve need to be installed to fit flywheel correctly :
cheers in advance
cheers in advance
farmboy555
06-17-2015 08:36 AM
rolape2
11-17-2011 01:44 PM
