Motorcraft Mercon V not for transfer case?
I just bought some Motorcraft Mercon V for my explorer's transmission. It says on the bottle not for transfer cases. What is supposed to be used in the transfer case? The manual calls for Mercon, but Ford discontinued it.. I know there are "meets" mercon spec oils out there, but what is the official word on this from Ford. Any info??
The 04' Explorer has auto push button 4wd, no manual 4X4 was offered. You can still get Mercon/DextronIII ATF in the stores. It will not be Motorcraft but so what. I have some Castrol Mercon/DextronIII on hand and put Amsoil ATF in my trucks transfer case which is somewhat universal. Mobil also makes a similar synthetic ATF that meets the Mercon/DextronIII requirements.
The "official" word from Ford can be found here:
FCSD Chemicals and Lubricants
The Workshop manual for the 2004 Explorer specified Mercon for the transfer case. Since Ford has issued a blanket statement to use Mercon V for all applications where Mercon was previously specified, the correct fluid for your application is Mercon V.
I notice those Motorcraft lube charts do not contain any transfer case information. OT: CVT and dual clutch transmissions are very different animals than conventional automatics. I wonder how many are going to be damaged by owners or unqualified shops using the wrong fluids. Honda cant keep its CVT's alive even with the correct fluid.
The correct fluid for Ford 4 wheel drive transfer cases is now Motorcraft XL-12
Transfer Case Fluid
The cost at Tousley Ford Parts is $6.60 per quart
Tousley Ford Parts Depot
Transfer Case Fluid
It goes back to the original question and what is so special about a Borg Warner chain drive transfer case that it needs a special lubricant and not just any ATF. Its like when Ford owners manuals still called for Type F in power steering systems decades after Mercon came out for transmissions. It was lazyness or no budget in engineering and a CYA attitude. Mercon was eventually approved. At least they didnt come out with a more expensive "special" fluid for PS systems, like Honda.
Syncrowave
30
09-28-2017 08:33 PM
Skauber
1997-2006 Expedition & Navigator
18
04-02-2017 07:45 AM
