Louisville Gauges?
Louisville Gauges?
I'm doing quite bit of work on an '88 L-9000, and I have a LOT of parts to swap over from a '96 L-9000..... The big thing is that I'm swapping to the '96 L-10, and all of the related wiring. I have everything outside of the cab ready to go, but the inside..... Anyway, I still have the original tachometer -it was set up for an L-10 Cummins. Will the new sender fry it? The new sender was original to the '96 L-10 - I'm wondering if the '96 sender will talk to the '88 tachometer.
Rodney
Rodney
The old tach has just a rotary switch to choose between different engines. The newer tach has the tiny switches on the back. I have no idea on the number of teeth on the flywheel, as the old L-10 was gone when I got the truck. I was just going to switch the tachs, BUT the new ones has 5 wires, and the old one 4 not sure what I would do with the extra?
Rodney
Rodney
Rodney R
06-07-2015 05:54 AM
