5.0L Coyote 5.0l Ford OHC Coyote engine for 2011+
f150 5.0l Crew cab 2012
Old 01-24-2012, 12:29 AM
Marko1's Avatar
Marko1
Marko1 is offline
Question f150 5.0l Crew cab 2012
Hey Guys,
I've been jumping in the 79's Forum for a long time creeping mostly but Making the leap to a 2012 F150 Crew cab 5.0L XLT now i'm reading alot but havent seen anyone really saying what how many KM's they get to a tank? (Sorry Canadian here i can Convert to Miles) Just wondering and is it a 98L tank or running a 136L tank on everyones?
Old 01-24-2012, 10:26 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Hey Marko1. You might also try posting this in the 2009+ F-150 forum here:2009+ F150 - Ford Truck Enthusiasts Forums
Lots of the guys with these trucks hang out there and you might have a better chance at a good response there.
Old 01-26-2012, 05:52 AM
640 CI Aluminum FORD's Avatar
640 CI Aluminum FORD is offline
My truck
2011 F-150 FX4 Supercab
5.0L V8
3.73 rear end
City MPG = 17 (Converted) = 13.8 Liters per 100km
Highway MPG = 22.5 (Converted = 10.4 Liters per 100km
Avarage Mixed City Highway = 19mpg (Converted) = 12.3 Liters per 100km
My truck came standered with the 36gallon gas tank or 136L tank and I can generally go between 630 to 650 miles per tank of gas...Or 1.013 to 1.046KM per 136L of fuel.
Hope this helps. I consider this mileage phenomial considering that my truck is a 5500lbs 4X4 V8 gargantuan. But on a side note, I do drive pretty easy to conserve fuel and reduce wear and tear.
Anyway, good luck!
Old 01-27-2012, 01:34 AM
Marko1's Avatar
Marko1
Marko1 is offline
Thanks 640! Exactly what i was hoping to hear from at least 1 person I'm Looking at a 2011 now too bit cheaper and Figure same as the 2012 basically anyhow And they are throwing a bunch of stuff on it So that sounds great! I will post what i end up with here for sure!!
Old 02-04-2012, 11:27 AM
colemac's Avatar
colemac
colemac is offline
Originally Posted by 640 CI Aluminum FORD
My truck
5.0L V8
3.73 rear end
Anyway, good luck!
I have the same configuration besides a supercrew and still on first tank. The best I have seen so far is 16 litres per 100kms. Will it get better for the next tank.it said 835 to empty when I got it. I am wanting to get numbers like yours.
Thanks in advance,
Old 02-09-2012, 03:43 PM
Brandon150's Avatar
Brandon150
Brandon150 is offline
Averaging 19mpg!?!? Wow, wish I saw #'s like that...
Old 02-09-2012, 03:53 PM
colemac's Avatar
colemac
colemac is offline
640 ci. how do i pm you? those are numbers that i was told i would get as well..haven't yet but still on first tank.
It has been around 15.5-16 litres per 100km which equated to about 750km's
That being said, will the truck get better or should i get it looked at?
thanks,
My truck
5.0L V8
3.73 rear end
Anyway, good luck!
Old 02-09-2012, 10:12 PM
colemac's Avatar
colemac
colemac is offline
thanks,
640ci
just got fuel tonight, took 123 litres and it says 750 to empty..i was told i would get numbers like you. is it because it was only the first tank of gas i purchased besides the one that came in it when i took delivery of truck? should i take to dealership or is this known from the start?
Thank you for your help,
Old 02-13-2012, 04:51 PM
colemac's Avatar
colemac
colemac is offline
640ci
Appreciate the help from 640 when he gets it
Mighty Mustang
03-03-2014 04:10 AM
Marko1
2009 - 2014 F150
01-27-2012 10:15 PM
mds47588
11-02-2008 08:27 PM
fireman649
1997 - 2003 F150
27
05-08-2005 09:01 AM
mikey58
03-12-2004 09:22 PM
Quick Reply: f150 5.0l Crew cab 2012
