57 f-350 quit idling/ running all together
57 ford F-350 292 Y-Block 2bbl 4 speed
I was driving the truck and I stopped, the truck stalled immediately, I got it to start up but it wouldn't stay running without my foot on the gas pedal. Then the truck quit running all together when I was going 50 mph and I was lucky enough to coast into my driveway with it.
I drained and cleaned the gas tank, blew out the fuel line, replaced the fuel pump, discovered I had a few pin holes in the main body of the carb, so I bought a new carb for it.
The truck still won't start, it will hit but it does not want to take off, and it shoots a flame out the carb. but it doesn't seem like it does it as a result of a back fire.
I am at a total loss, with it. The truck would always start even if it had a dead battery (roll it to start)
The distributor didn't turn or anything, it was tight. I replaced the condenser, tried to start the truck and it still wouldn't take off, but that did away with the fire problem, i ran a fine piece of sandpaper on the points, and checked the adjustment which was good.
I was able to start the engine and the engine would stay running as long as i had the starter engaged and it would quit immediately as soon as i disengaged the starter.
Long story short, I pulled the ignition switch out of the dash sprayed some contact cleaner on it, put the wires back. The truck fired up without a problem.
Thanks for the help, you led me down the right path.
