4WD doesn't work!
4WD doesn't work!
So the first significant snow we had this winter I find out the 4WD doesn't work! I'm so upset about this. I can't trust this to carry my family around in the snow and ice and I now have to take it to the dealership. I don't have anyplace to do the work myself and it's 14 degrees out. Merry Christmas to me!
4wd not working
Do you have auto's or manual/auto. I know on my 2002 the auto's get stuck if you dont turn them once in a while. I would recomend ditching the auto's all together and getting a set of warn or superwinch, Warn being my first choice. If you have the manual/auto hubs, soak them in WD40 and CAREFULLY! use 2 sets of channel locking pliers to wiggle them back and forth until they lock into place.
If thats not it check your vacum lines that run from each wheel to the passenger side fender just behind the battery.
what he said....
and have always heard 4 wheel drive will just get you INTO harder places to get out of don't most of those two wheelers do it without 4x4 !?!
the ex's are great in 2 wheel drive - let a bit of air out of the tires and drive it like you were on ice.... easy and slow change of direction...
besides 4 wheel drive won't help with braking and that;s when the problems start cuz some doofus was doing something doofus's DO
good luck and carry extra blankets in the back
Yep, get under the vehicle and check the rubber lines, I bet they are dry rotted or broken.... just like everyone else has said they work on vacuum..... also turn the hubs to the front of the vehicle this locks them in 4WD.
turn your blower on to blow out the vents........then put it in 4wd and see if it diverts itself to defrost on a pull........indicates a vaccum leak........mine did this and I replaced the vaccum lines to each front knuckle in about 10 minutes for less than 5 bucks with some bulk vaccum line from advance auto........the lines are routed with the front brake hoses and the ABS sensor wires
My air conditioner switched to defrost when I turn the ESOF ****. I changed the vacuum pump from partsguyed and everything is working perfetly now. I bought my 2000 Ex used this year and suspected that after being 10 years old the vacuum pump was probably the original...and it was. partsguyed hooked me up for $70.
Thanks guys!
I haven't been able to turn the hubs since I bought it in July (I never knew to check it), but the 4WD was working a couple of months ago when I tested it. Unfortunately, I either have worn clutch plates in the rear or an open differential, because only one wheel spins in the back. I'll do some testing with the vacuum lines to see if that does it.
Can someone explain the "be careful" when using WD40 on the hub? I would be just fine locking them manually for now.
Thanks again!
Thanks again!
Thanks for the Channel lock trick! I was able to get the hubs turned, quite easily too! I was never able to turn them by hand, but I barely had to use any force with the channel locks. I got as much WD40 on them too, before I ran out of pressure in the cold that is! I'll be bringing them all in the house so they actually work. Unfortunately, I wasn't able to start the truck to check the vacuum. I've been having some cold start issues and it struck again, so it's on the charger. Anyone know where I can get some new battery cables or should I build them myself?
Well, I check out the vacuum lines and they look good, plus the HVAC works properly when I have it in 4x4. Now the good news...
I tried it today and it seems to be working fine! YAY!!!! It must have been manually locking the hubs or something, but it worked several times today! I'll take them apart this summer to clean and lube everything well to keep them in working order.
Thanks again!!!
Thanks again!!!
help i'm stuck!!!!!...Again
i have a ford X limited harley davidson Ed 1st got stuck in my driveway after a snowstorm in New England / MA, called AAA when it would not move they sent a flatbed he hooked the breast up in the front and then tried to pull in forwards in N didnt work so he had me put it in D and tried it again nothing then he got stuck i thought i locked the hubs and the wheels were spinning not together or at all . AAA made sure they were locked and they were got out today i'm trying to get up to the house on a very small hill 1/2 way up it stopped moving and started to go backward in D had the tires checked last Sat and 30min before the hill was told they are fine what gives!!!!! i have owned a ford explorer EB, expd EB, and now the beast(X) never had this problem before with the other two waiting again for AAA and Ford to call me back to get an appt
