Clutch rod fix?
Clutch rod fix?
FORD Clutch FIX, Rod End PERMANENT FIX powerstroke too - eBay (item 260719575462 end time Jan-19-11 10:52:48 PST)
Is this worth getting??
mine was non existant also...every now and again i would hear a squeak. then last week i pushed in the clutch and the pin on the clutch pedal broke off...luckily i wasnt far from home and my buddy with a roll back took it to his shop. if you dont get the ebay part...try to get a hold of the plastic insert...it may hold out breaking the pin off. good luck
It is a **** poor design. Definately one of those things you need to change out and check on as a maintenance item. Shouldn't be designed as such. Not something you think about and it is not listed as a replace every couple of years type of part. I read about that plastic insert shortly after I got my truck and am replacing it every year or two. Not a bad price for 40 bucks considering it becomes a permanent install. No need to replace plastic clips anymore.
wreckinball
07-14-2010 08:50 PM
60RatRod
04-11-2008 09:58 PM
