FT or FE???
Old Mar 10, 2003 | 02:42 PM
lilpig88's Avatar
lilpig88
FT or FE???
i have a 360 ('76 f150) that will most likely need a rebuild soon. i've been reading a bunch on here and noticed that many people have said that trucks tend to have FTs?? would this be the 361 or 391 then? if i'm going to rebuild, (haven't checked casting numbers, etc. yet) i'm assuming that i have a 360 FE, but what's the difference b/w the 361 FT? One more thing: are there any chances that no compression in a cylinder means a valve problem instead of rings? is this a "common" problem?
thanks
Old Mar 10, 2003 | 06:59 PM
Ratsmoker's Avatar
Ratsmoker
FT or FE???
Those engines are FE engines. The blocks have many similar characteristics of FTs though. The block has extra main webbing and usually thicker cylinder walls. The distributor hole is cast for the FE distributor but bushed down to use the FE distributor. Every part in that engine is an FE part. No compression usually does mean a burnt valve or a hole in the piston. Bad rings will give low compression but never zero.
$Bruiser$
Sep 1, 2019 04:55 PM
graysvintage
Jun 10, 2012 02:04 PM
Hercules
Mar 30, 2012 08:19 AM
tylstruck
Dec 18, 2007 08:38 AM
banjopicker66
Jul 27, 2003 10:44 PM
