Throttle surging after new lift pump
My truck throttle surges at random really bad after puttin the new lift pump on a couple days ago. That was the second time iv driven it over 50mph since install ..my buddy said it's just stuck air bubbles and that his throttle surged for about a week .. Normal?
Nope, not normal at all - I've had my fuel system open gazillion times, never had a surge for more than a minute, if that. Are you sure the line between the lift pump and the filter head is seated and sealed properly on both ends? Altho that would result in a fuel leak, while what you have going on sounds more like an air intrusion between the tank and the lift pump somewhere...
on
nah,once shes running the air will purge in just a few seconds.
see,the fuel runs continually through the system.whatever is not used by the engine cools the fuel system and returns to the tanks.
(this causes condensation by the way,and is why a water separator is very important.)
for you to have a problem while running,means more is being let in.
it's hard for the stock puller to pull fuel with an air leak on its suction side,and it will cause your trouble.
on
The pump is irrelevant ... A leak on the suction side introduces air into the fuel stream.
Just because fuel is not seen leaking does not mean there is no leak!
Air is smaller then fuel, thus it can leak air and not fuel!
What you are describing is starvation, either from air in the fuel or inadequate flow.
Did you replace the rubber hose from the frame to the lift pump when you replaced the lift pump ???
-Enjoy
fh : )_~
-Enjoy
fh : )_~
on
No, The IP relies on the lift pump pressure for nothing other then providing fuel ... The return system makes it kinda like pouring fuel into an open container.
Yes, If you were to block the returns, pump up the pressure inside the IP it will affect the timing, in an uncontrolled manner. And likely destroying the IP.
Air in the fuel means less fuel in the cylinder, less fuel in the cylinder, less RPM's, thus the surge ...
-Enjoy
fh : )_~
-Enjoy
fh : )_~
