1994 F150 ECM fried
02-03-2011, 06:59 PM
on
1994 F150 ECM fried
My ECM/PCM burned up (one of the capacitors is smoked.) Looking at other posts, most of the time the ECM is the root cause. While checking for shorts, I found that the TAD/AIRD was open. Then I found the connector neatly tied up to the engine harness. Should there be a diverter solenoid, or does my model not use one? 1994 F150. 4.9L E4OD. Any insight is appreciated.
02-03-2011, 07:44 PM
The caps will go out from just being old.
The AIRD is the diverter solenoid.
02-03-2011, 09:30 PM
on
Right, but there is no diverter solenoid. The connector is tied to the harness and looks like it has never been plugged in. Is it missing, or not applicable?
02-03-2011, 10:43 PM
If you have the calibration number off the drivers door I can pull up a diagram and see.
Or if you still have the vacuum diagram under the hood you could look at it and tell.
02-04-2011, 07:38 AM
You can have that capacitor on your ECM replaced on an electronics repair store, it should work ok if no other issues come up.
02-04-2011, 06:40 PM
on
Calibration sticker says 3-52H-R10. It also says F3AE-6E061-HHH.
The circuit board is melted.
02-04-2011, 07:45 PM
No you do not have a diverter solenoid.
The calibration numbers diagram:
02-04-2011, 09:06 PM
on
Thank you very much for the information.
Cannondale372
51
07-07-2023 11:59 AM
abranz
05-19-2017 10:18 PM
WheatWhacker97
01-09-2016 06:20 PM
sportsman70
04-24-2015 07:09 AM
GuitarJesus
10-21-2014 05:22 PM
150,
1994,
352hr10,
burnt,
calibration,
capacitor,
ecm,
f150,
ford,
pcm,
pinout,
problems,
ranger,
truck,
v8
