a real econoline steering fix!
#511
I was running worn 265/75/16's at the time and had to get the rubber hammer out. Then I put new 265/75/16's on and had to get more creative.. Then I sold it.
#512
I'll stick with my 245's since they'll be Michelin LTX's E-rated. That's been a good brand for me, the size pretty perfect too.
Thanks ReBar13!
#513
Bingo! Its not the lack of a steering damper band-aid.. Its the lack of caster.
After mine was adjusted from 3 to 5 degree's I took the stabilizer off because it was junk, and felt no difference other than it was harder to steer after I installed the new one.
Apparently this thread about the steering damper must have a placebo effect
#514
I don't wanna sound like we're piling on against the steering damper but within one day of installing my new from Ford parts it was all removed and sold to another member here. I didn't notice it correcting my issues so didn't see the wisdom in keeping it installed.
Addressing the rear suspension (springs, mounts/bushings, shocks, sway bars etc) along with increasing positive caster would seem the better way to have a more stable ride. Its easier to bolt on fixes rather than dig into other issues that might be causing ride problems.
#515
Hi there Andrew....I've read through this thread and found it very interesting. I was puzzled about what folks were talking about how vans handle since I'm very small and really never had a problem with the 95 I bought. However, after reading through the thread when I had it in for some mechanical work recently I asked about whether it had a sway bar or whatever installed....turns out I lucked out with mine....it had had one installed. No wonder it drives so nice. Thanks for all of the information you have put out on this for folks.
#516
I struggled with my van's steering on the highway. I'm surprised no one called the police on me thinking I was impaired. It was a wandering fool. Wind, groves in the roads left by trucks, passing big trucks, etc. would cause it to wander. I only put 9,000 miles on it the first 3 years I owned it, so I didn't make it a priority. Well, I've being putting on 3,000-4,000 miles a month on it this year and had enough. I bought the alignment sleeves and had it aligned with maximum caster. It drives like a different van. I don't have to grasp the wheel tight with both hands when I pass a truck. Should have done it 3+ years ago. I couldn't find the Ingalls 594, so I got the AC Delco 45k6525.
#518
#519
#520
Just don't do what I did and ask for maximum positive camber. It was early and I didn't have my coffee, yet. And that's exactly what the shop did. I had to pay to have it aligned, twice.
#522
The stabilizer doesn't fix issues, nor is it a replacement for new parts needed somewhere else. It just takes a normal healthy van and makes it steer better. It also stops the wind throwing it quite so horribly when you are on a windy interstate. It helps with bump steer and most of the nay sayers haven't bolted one on their vehicle. My caster is set to 5 degrees and it still helped. Drove it without the stabilizer and then with it. Glad it has helped some.
#523
I myself did install and test drive the factory system but it alone didn't provide the "fix" I was hoping to find. For simplicity's sake it was removed and sold here a few days after that installation. At the time I wasn't aware increasing my caster was so important to taming the tail wagging effect I find distracting and uncomfortable.
From me thanks for starting this thread! Reps sent, others should maybe consider the same action!
#525
