limited slip
Old Mar 10, 2003 | 12:41 AM
metallicafan's Avatar
metallicafan
Question limited slip
hi everyone, i have a 1990 f250 4x4 with the ford 10.25 rear end with 3.55 gears, right now i got open diffs, i realy want some limited slip but i dont have that much cash, i was thinking of getting the ford factory traction lok and putting that in the back, possibly something like that for the front???? anyone know anything about this, anyone know where i can get the parts, anyone ever dont this???
Old Mar 10, 2003 | 06:11 AM
aldridgec's Avatar
aldridgec
limited slip
Sometimes a little search can help!
I've just been discussing this! Look here:
https://www.ford-trucks.com/forums/s...hreadid=103070
and here:
https://www.ford-trucks.com/forums/s...hreadid=103361
Finally, randy's ring and pinion is one of the best places to get parts. http://randysringandpinion.com
However, if you want the Factory LSD, contact Sessler Ford at : http://www.sesslerford.com/multiframe.asp?content=parts
They have it listed for $190 for the Semi Float, should be the same for the Full Float axle.
I would try the one LSD in back if your strapped, doing the front isn't fun and probably not really neccesary. If you need it in the front you're probably better off spending the money on a locker for the rear instead.
Chris
