49 truck with 4.6 modular motor-IT'S ALIVE!!!
#301
I finally finished a little more fab work on my battery box and got it painted. I used the the battery hold down from my wrecked Focus.
I also finally got got my electric fan mounted. A very time consuming project but I’m very pleased. I’ll probably add a little bit of adhesive backed foam on the edges. The fan size was almost perfect. I just had to modify the corner. My fan controller should be here in a couple of days.
#302
I’ve been dreading this part of the build the most. I’ve put it off and put it off but I have to get it done now to continue with some of the rest. Since I cut the one piece front end apart the hood had no lip for any rubber bumpers and the inside edge of the fenders don’t extend far enough for the hood to rest on. I decided to try the hood first. I’m very happy with how it turned out. I’ll have to wait until the fenders are finished so I can set the hood on and do the finish shaping.
#303
#304
#306
One of the biggest issues for me was just being limited space wise. I’m trying to keep everything that I can inside the cab and these ‘49’s are small.
#307
#308
Finally the weather is cool enough to start on more fiberglass work. I took the clip outside and began the sanding. 40 grit on a belt sander worked good on the top. I used a belt sander, die grinder and a scale remover on the underside. After sanding I moved it back inside as rain was approaching. Here it is with the form made out of insulation board. I still have to apply packaging tape over the foam and then start laying some resin and fiberglass mat.
#309
The weather decided to get warm and muggy again so I’m putting the fiberglass work on hold for now. I decided to alter the taillight to swing out instead of up for my fuel fill. I just hope I’ll have enough room to get the fuel nozzle to the filler tube now.
https://youtu.be/NezP4VYCuLo
#311
#313
#314
#315
Since this was a tilt front end, the lower fender sections were separate pieces that bolted to the running boards and the rest of the fender lowered on to them. Since I’m not tilting I used epoxy adhesive to glue them together. I then used the belt sander to better shape them with the fender curve. I then v’d the mating line. I’ll be using duraglas to blend this as well.
