49 truck with 4.6 modular motor-IT'S ALIVE!!!
#286
#287
#288
I’ve been dreading it for a long, long time but I finally got started on the hidden hinges for the passenger door. It’s been quite a while since I did the drivers side. I put in a lot of time on it today and still not finished. Hopefully 2 more hours on Monday will finish it up. Then I’ll start on the bear claw latches.
#289
#290
I only got a couple hours to work on the truck this weekend. I did some studying on how I’m going to use the factory door handles and assembly to work with the bearclaw latches. I think I’ve got it figured out in my mind so I went ahead and got the latch fabbed in. I’ll work on the striker bolt and handle assembly Monday.
#291
#292
Man having a down week at work really helps with getting things accomplished. I just finished fabbing some seat mounts and I had to alter one of the front legs on each seat. I just got them installed, hooked up the power and ground and I now have power leather seats! I’ll try to get pics tomorrow.
#293
I went back and forth between getting a bench seat and using what I already had. I ended up using the bucket seats that were free! I had to add 2” taller mounting blocks for the rear. I also added 1/8” plate for the front. I love the way they fit and although there isn’t a lot of room in these small cabs for adjustment the ability I have with these power seats is great.
#295
Thank you. No they’re actually out of an ‘06 Freestyle which is my wife’s daily driver. We had a massive failure of the notorious CVT in it several years ago. Instead of replacing the transmission for $6500 I bought a wrecked ‘08 Taurus X and completely gutted the Freestyle and turned it into a Taurus X. So I saved the seats knowing I could use them for my truck.
#296
Such a great Thread.
Took seven years to get my Truck on the road. Pics / Clips really capture the reality of the "frame-up" journey including, life getting in the way. I like the mod engines and always wanted to see how well they fit. Custom work isn't my particular taste but boy do I respect the work! Especially the Floorboard.
Paintings are unbelievable as well. Great talent. National Geographic Cover Afghan Woman was found 17 years later. She'd had a hard life.
#297
#298
Man do I hate going backwards on projects. For some reason it appears the new carrier bearings in the 9” rear are shot. I really wish now that I would’ve done the explorer rear conversion. Oh well, I’m gonna replace the bearings, try again to set the carrier bearing preload using the adjusters and see what happens. Also going to order a high amp relay and fan controller to get my electric fan operational.
#299
#300
