zrf 5spd huh, have u heard of anyone doing this, im not too experienced so i want to know everythimg i can b4 i just jump in, if i didnt know b4 i would just get my grandpa to help, but i guess i get to learn on my own now
I wanted to do the zrf 5spd conversion to the fe but at that time did not heard of any one doing it and no adapters were on the market 3 yrs ago. I have heard some talk the someone was working on an adapter setup but don't know who it was thou..
Well my truck is a 4x4 with diff-crossmenber for 1 thing.so you'll have to cut an weld a step in for the dodge mount. 2. Cut your drive line shorter plus install slip yoke for driveline $300. 3.Cut a new hole in floor hump cover. 4. drill lager pilot bushing hole to 3/4"to match front chevy input shaft . 5 Use a chevy 11" 10 spline clutch disc. 6 Change from dodge to chevy v8 gas motor input shaft (cause it's smaller 1.1/8" so the ford throw-out bearing can be used. 7. Buy tranny advance adapter a few 100 bucks. 8.tranny $1000...
Just off the top of my head
