Front axle won't engage
I have a 98 Lincoln Navigator
The switch on the dash works, the lights indicate that it is in 4wd, when I switch it to 4lo I hear it engage and the front drive shaft won't move when in 4lo (moves normally when in 2wd).
The actuator on the axle seems to be holding pressure, but nothing is being sent down to it. Don't seem to have a leak in a vacuum hose.
I have removed the 2 solenoids behind the battery for replacement but wanted some opinions before I spent the money. Any ideas?
Yeah, by hand. When in 4low, on ice when I floor it, only the rear wheels spin (the others roll fine but are obviously not locked in).
I had no vacuum whatsoever to the actuator on the axle when I disconnected the hoses, not in 4lo, not when switched back to 2wd. The actuator wouldn't move when I held my fingers to the nozzles on it. Moved fairly freely otherwise.
I do have vacuum at the hoses when I disconnect the ones at the solenoids behind the battery (only one hose on each though).
Man, I'm stumped.
yotesniper66
1997 - 2003 F150
05-27-2020 05:47 PM
w74bronco
02-09-2014 12:40 AM
Pinhead-227
02-14-2008 10:02 PM
ARTURO TOSCANO
08-19-2002 12:43 PM
