Coolant smell from the heater/defroster
I hope i never have to do mine either. Easiest was in a 78' Chevy silverado half ton. Took maybe an hour cause a took the time to wash the heater box. Worst was a 87' Camaro. Took 8 hr's. Had to drop the column and remove the entire dash assemble. I never did figure out where all the screws went back into. I had about 200 in my parts dish and only put about 190 back in.
Bad heater core.You can bypass it by using a 5/8 hose connection male/male and using factory hose claps. I just did mine and It wasnt too bad 6 bolts in dash and dont forget to remove steering shaft( its keyed so dont worry) and other electrical connects. While you there clean Evp core also mine was 50% clog with dirt and stuff. It took about 6 hours from start to finish.
bigg471
01-16-2017 07:05 AM
