C6 Trans Cooler. How Important?
When i installed a new aluminum radiator in my 78 F250 i noticed the aftermarket trans cooler looked pretty rough so i took it out. My question is how much do i really need one and is the connections at the radiator good enough to cool the trans? My truck is a 4x4 and lifted with 37" tires and 4.10 gears. I only drive it occasionally or if i go camping and only tow a tent trailer thats all aluminum (only 1600lbs. with 8' deck on front). Would a deep trans pan with extra capacity be alright or should i put a new trans cooler on it or both? also the trans has a shift kit and low miles since rebuild and works great and i want to keep it that way just dont want to spend extra money if not really needed. Thanks for any input.
your tranny will build heat threw friction and the fluid will get hot and if left unattended it will keep getting hotter and hotter until it boils and will destroy the seals in the tranny and render the tranny useless ( HEAT IS THE TRANNYS WORST ENEMY ) !
when your engine heats up so does the tranny fluid and if your engine overheats so will your tranny fluid ! it is best that the tranny has its own separate cooler and bigger is better ! bigger lines will also help sometimes as would a tranny temp gauge !
Agreed...wouldn't hurt having one, but I don't see it being necessary for a commuter.
On my heavy haulers or trail/mud rigs, I just run them in series...usually in to the radiator first, then the aftermarket cooler, then output to the tranny.
WOW, lots of mixed opinions so here's mine, depending on were you live if you live in the colder area it would be a good idea to have a cooler and have it go thru the bottom of the radiator to help heat up the fluid for cold driving so the trans shifts a little smoother.
But by all means you do need a cooler, those fittings were not put in the side for looks.
It is slightly unrelated, but I had a trailblazer I towed a 5,000 lbs camper with. When I bought the camper I bought a B&M aux. trans cooler and a temp gauge. If I ran around town, trans would warm up unloaded, if I ran the highway less that 120 deg. nomatter the season. you hook that camper on and in third gear (4spd) it would run 180- 200 consistent. if you put it in OD and didn't keep track of the converter locking up, it would climb from 180 to 230 in less than 2 miles. with a C6 the OD heat won't be an issue. if you want to see what is going on get a temp gauge. they will let you know in a pretty quick amount of time, if what you are doing is going to damage the trans.
A rule of thumb is if your temp gets above 200 degrees for a significant period of time, you just cut the fluids life in half. if it is good for 50k it know will be good for 25k. I am not sure if my temp numbers are 100% correct, search trans fliud life and you can read what the pros say.
SoCalAngler
1999 to 2016 Super Duty
37
08-13-2020 10:52 PM
lud04X
08-15-2016 09:21 AM
Island'r
12-28-2015 10:45 AM
Leichardti
02-15-2013 04:42 PM
