F250 Clutch SMF Vs. DMF
Add one more to the list of people who've never heard the "smf will wear out your zf-5" statement - or ever heard of anyone its happened to...
I've had an smf setup in mine for a couple of years now - ever since I swapped a zf-5 for my old T-19.
If you want to go smf and do if for under $300 here's the poop on how to do it.
Go to Autozone and order the following:
Clutch disk part # CP31103A - it is splined for the ZF shaft (1-1/4") and has the springs in the hub (the "A" on the end of the part # is for Anti-vibration = springs in hub)
Pressure plate part # CA31055 - this is the deeper one for the SMF
Throwout bearing part # 614062 - this has the big center bore for the ZF and a face profile compatible with the release fingers on the SMF pressure plate
All of that will run you right about $175
And lastly get a refurbed flywheel from Napa - part # NNC 50710 for about $90.
Then read these two threads
https://www.ford-trucks.com/forums/6...uestion-3.html
https://www.ford-trucks.com/forums/6...body-lift.html
It's all straight forward bolt together stuff.
There are also some pretty helpful pictures of the process in my gallery...
im pretty sure it was Festus who was also talking about the SMF wearing out ZF5's over time. haven't seen him on in quite awhile though.
and yes dual mass absorbs the engines shock load so the driveline operates more smoothly. with less noise.
i have driven several 3/4 - 1 ton ford diesels 2 of which i know for sure have dual mass. 1 being my own after checking. and the other i know its dual mass because i installed it. they both have a decent level of pedal resistance. not so much your going to have a leg so strong your gonna kick like a horse after driving but not so light you cant hardly feel it.
1 3/4 ton had a manual trans with i assume single mass because i got in there after driving my truck and damn near put the pedal through the floor. i could push it with my little finger....... i did not like that. if thats what single mass feels like and that's what your going for then ok. it went through the gears ok. had some rollover noise. but i myself need some resistance on my pedals.
most vehicles ive driven have the same amount of clutch pedal resistance as my truck be SUV, 1/2 ton, 3/4 ton, 1 ton.... all have different levels being different vehicles but no real extreme variance outside that 1 truck.
But I don't see any benefit to their SMF kit over my pieced-together Autozone/Napa "kit". Unless spending $300 more to get it all in one box is considered a worthwhile "benefit"...
#28
on
Yes, the SMF will beat your ZF to death ... Yup, it may take years, but it'll happen!
Most of us will likely never live to see it happen, depends on how much you idle your SMF Diesel.
The DMF does not absorb drivetrain spikes ... The springs in the DMF are no where near strong enough, under load the DMF locks up and becomes like a SMF.
The purpose of the DMF is to absorb the rotational Pulse caused by a idling Diesel Motor, thus what causes Gear Roll Over thus what will in time beat your ZF's gears & splines to a pulp!
This did not become an issue until technology started playing parts and components were being made closer to their maximum yield. (i.e. Smaller and lighter)
Best way to explain the issue is ...
Take two fingers on one hand and give the Peace sign ...
Take one finger on the other hand and stick it between the other two ...
Then shake the hand with one finger ... It will beat the insides of your two fingers on the other hand!
Same thing happens to the gears & splines in a Diesel Transmission.
-Enjoy
fh : )_~
-Enjoy
fh : )_~
#29
