Intake Manifold and 4 Barrel Suggestions Needed for a 352
#31
My gears & tire setup should have me running 2494rpm at 65mph. Various things I've tried haven't changed the mpg's much though. I know the FE was never designed for fuel economy and the Slick design is not the most aero-dynamic but it still seems like it could be better than what I'm getting now...
#33
#34
Do you have headers on yours?
#35
#36
My '65 F250 has a 352 / 2bbl. I need to replace the intake manifold gaskets and figured since I was going to put a 4bbl on it, I might was well do it now.
I was thinking of an Edelbrock Performer intake manifold and a Holley 600 CFM 4bbl with an electric choke.
Thoughts, experience, suggestions?
Also, suggestions on how to jet it for a stock 352 are welcomed.
#37
No headers yet... I also have the Pertronix ignition, I tried the MSD Distributor, with the 6AL box, and High output coil, while the power was great , it had no Vacumn advance so the mileage dropped off quite a bit ie; 5-6mpg. I Have purchased headers for it, but have yet to install them. I have the stock exhaust Manifolds but I took a die grinder, and opened up the ports so they match the heads better, it was a surpising difference. I have considered dropping in 3.54 rear gears as that is the best I can get for the Dana 60 but I am thinking now that maybe a swap for a 5 speed overdrive would be a better choice. I want to keep the manual gear box, SO I have been trying to find one that will be a good mate to the FE Series of engines...Ahhh decision decisions!
#38
#39
forgot to put this in there Edelbrock 4 v manifold
#40
#41
#42
Ok we are most of the way there...late start and some parts not working as designed. If you have a 2 barrel intake, do NOT get the Transdapt 2 barrel to TBI adapter plate. It was a nightmare. Over an hour of grinding and shaping later I did get it to work, but I would much rather have paid the extra money for the Holley part.
At this point everything is wired up and ready to go, just need to finish running the fuel line and getting the throttle and transmission kick down hooked up tomorrow and we will be ready to tune!
We also took the time to add an additional fuse panel for accessories even though it was not absolutely necessary.
#43
Guys, Ive been running a 352 in my old 66 for a few years now. Damn its a tough motor. Anyways, I'm having a really hard time keeping the valve covers sealed. I understand that FE blocks are almost impossible to seal but I'm putting in a few quarts of oil a month in it an I've tried almost everything. I've used rubber, cork, silicon, an even silicon/rubber combo, but none of it seems to work. Any thoughts?
#44
#45
I would agree with drstjeeper. When I first got my 66 with a 352 it was leaking at the valve covers and the pan. I replaced the valve cover gaskets and added a 4V intake & carb. It still drips a bit from the pan but I go 2000 miles before adding any oil.
