POP-ups WTF
Old Jan 23, 2011 | 11:14 AM
Anafiel's Avatar
Anafiel
Look at this screenshot. You'll see the highlighted line at "ads149 dot com" with it's filter.
That is the culprit. It generates a frame that translates to default.com. Use the filter I have there and that should stop the pop-up.
Old Jan 23, 2011 | 11:15 AM
Anafiel's Avatar
Anafiel
Here is a direct link to the image if you can't read the one above
http://i303.photobucket.com/albums/n...Now/Filter.jpg
Old Jan 23, 2011 | 11:25 AM
Anafiel's Avatar
Anafiel
Originally Posted by desperado_18_2000
I'm using Firefox 3.6 and to get the pop-ups to stop I had to go into Tools/Options/Content and remove a pop-up blocker exception for FTE to get the pop up ad's to stop. This same menu can be found in Linux by going to Edit/Preferences/Content and finding the same thing.
I think you can add your exception back for FTE if you add the filters ctubutis and me added. Don't want to have to limit your experience here at FTE because of spammer scum...
Old Jan 23, 2011 | 01:05 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
My norton has been blocking it successfully. According to Norton the one trying to infect me is coming from "ads320-dot-com".
Most likely "ads149 dot com", and "ads320" are from the same domain.
Old Jan 23, 2011 | 01:21 PM
ctubutis's Avatar
ctubutis
We should just block ads*.com
Old Jan 23, 2011 | 03:32 PM
scalladaballa's Avatar
scalladaballa
I've been running IE9 on Windows 7 Ultimate X64. I have not had the pop ups people are describing...nor do I have the pop up blocker making any sounds...
And I have this website on my screen all day, every day. But I am running it in the 64-bit edition of IE9. Been good to thus far.
Just thought I add my experience.
Old Jan 23, 2011 | 05:40 PM
Rogue_Wulff's Avatar
Rogue_Wulff
I'm running win 7 x64 as well, but IE8. The only thing I get is the bleeps from the popup blocker. No notice of a blocked popup, just the bleeps. Happens everytime I click any link within FTE, as well as when I close the page or exit this site.
I gotta admit, the annoyance is minor, but still keeps me from reading all the threads I would typically check out, so it is possible that a question I know the answer to is totally overlooked, due to me getting annoyed at the issue and leaving the section/site.
Old Jan 23, 2011 | 09:03 PM
ctubutis's Avatar
ctubutis
You could mute your sound temporarily....
Old Jan 24, 2011 | 07:31 AM
6fifty_f1fifty's Avatar
6fifty_f1fifty
I should have stated at the beginning that I was running OS X 10.6, and browsing with Safari. Viruses, while not non-existent for the Mac are highly unlikely. And the pop up blocker worked immediately.
I guess I am just lucky that Apple didn't make the sucker make a noise or little banner up at the top notifying you of an attempted pop-up.
It doesn't make sense that this is driven by javascript in the ads, when the page my browser loads does not have ads in it. I suppose the code is still there, just hidden by my membership...
Thanks to all for the multitude of replies and info, I am sad that this is affecting so many users of this site, hopefully it can be fixed...
Old Jan 24, 2011 | 07:52 AM
ctubutis's Avatar
ctubutis
The admins are working on it....
Old Jan 24, 2011 | 10:12 AM
6fifty_f1fifty
At work, we run 32bit XP/IE7 and I don't seem to have issues at all, who knows what security package my IT weenies have running on these though...
Old Jan 24, 2011 | 10:21 AM
arctic y block's Avatar
arctic y block
I'm getting them also. It's irritating.
Old Jan 24, 2011 | 01:00 PM
  #28
dohc_chump's Avatar
dohc_chump
This space for rent...
Agreed. Since this first started happening I've kept away for the most part. I'm running Firefox 3.6 and just removed the exception for FTE on my pop-up blocker as desperado mentioned. Hopefully that works or I'll be gone till things get straightened out.
Old Jan 24, 2011 | 01:08 PM
  #29
CamoLaw's Avatar
CamoLaw
I had been experiencing this all weekend, but it seems to have stopped as of this morning. Maybe the admins fixed it?
Old Jan 24, 2011 | 01:22 PM
  #30
Rogue_Wulff
I'm not getting the beeps to indicate a blocked popup. An hour ago, they were still occuring.
We'll see if the issue is resolved.....
