alright how do you get the end link off @ pitman arm?
Guys, doing everything from the pitman arm down steering related, got both left and right off using a pickle fork on the air chisel. The link on the pitman arm is being stubborn. I don't have a torch or else I would have hit it with heat already, letting it sit with PBblaster overnight. any tips or just keep working it? Really don't want to damage the steering box
If you have to bang on that thread for the joint to pop it out of the pitman arm, make sure to keep the nut of the joint on the thread before you strike it with a hammer. I had to replace my entire link and joint because I didnt put the nut on to absorb the force of the hammer striking the threads, which munged em up ad made it impossible to put it back on.
Glad you got it off, but here is a tip for future people.
As you guys all know the tie rod ends all have tapers on them and the hole in the pitman arm and holes in the knuckles on the axle are tapered and coned shape. If you spin the nut off and then use a big hammer you can hit the narrowest part of the pitman arm and knuckle and this will cause the tie rod end to pop out and you don't have to heat up anything or risk tearing up your rubber boots when you use a pickle fork with a air hammer. You want to hit in the red box area in the direction of the red arrows in the picture below, and make sure you don't hit the threads of the tierod end because it will make it hard to reinstall the nut. I can normally get each tie rod off with about 2-3 good hits with a 3pound hammer.
ANOTHER TIP: Leave the nut retaining the tie rod, ball joint, or whatever it is that you are removing, attached loosely, by the last 3 threads or so, so when your parts come apart, they don't hit you in the head or fall on your foot. It will also protect the threads, as mentioned above, in case you miss & planed on reusing what you are removing.
