Wanted: 19.5" or 17.5" Rims off F-250
Old 01-21-2011, 04:53 AM
fordman75
fordman75 is offline
fordman75 is a splendid one to beholdfordman75 is a splendid one to beholdfordman75 is a splendid one to beholdfordman75 is a splendid one to beholdfordman75 is a splendid one to beholdfordman75 is a splendid one to behold
Andrew I sent you an email.
Here I thought the rims on my old 1956 F250 were the stock rims. Guess not if they didn't have them until 58.
Old 01-21-2011, 05:46 AM
truckdog62563's Avatar
truckdog62563
truckdog62563 is offline
truckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant future
Bill - The Chassis Manual does show them listed for 1956. Stu
Old 01-21-2011, 06:36 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Yes, you are correct, B8D-1015-A is listed in the 1948/56 catalog for 1956 (I edited in the info). I didn't look in this catalog (stupid of me), I only went by the part number's prefix.
But, what was the part number in 1956? It wasn't B8D since this is a 1958 prefix. When Ford updated the part number, did Budd update their number?
I couldn't find the original 1956 Ford part number listed in my O-S-I (Obsolete-Supercede-Interchange) catalogs.
Old 01-21-2011, 07:06 AM
truckdog62563
I don't find a 1956 Ford part number in the wheel listings, and my Hollander doesn't list it either. NWRA info shows the '56 Budd number was 70720 which then changed to 73240. I've got one of each different number and they look exactly alike, so I've assumed it was just a number update like so often happens with parts. But with both Ford and Budd numbers having changed, maybe there is a subtle difference in each that isn't obvious to the eye. I guess it's academic, either or both will work for Andrew.
Edit - I just remembered that my buddy Rusty has an original '56/'57 Chassis Manual. I just called him and will try to walk him through looking up the original '56 number when he can get to his shop and grab the book. Stu
Old 01-21-2011, 08:01 AM
NumberDummy
I tried finding the 1956 Ford part number by crossing over the original Budd number, but it's not listed in my 1957/63, 1964/72 truck parts catalogs.
Old 01-21-2011, 09:50 AM
truckdog62563
Bill - The '56/'57 Chassis Manual shows the 17.5" is #B6D 1015-A. The 19.5" has the same number as shown in the 1964 edition. Stu
Old 01-21-2011, 12:23 PM
49truck
49truck is offline
49truck is starting off with a positive reputation.
Originally Posted by fordman75 View Post
I've got a set of 17.5" rims that were on a 1956 F250 I parted out. The only problem is they are buried in my storage unit and they still have the rotted junk tires on them. And right now it's about 10 below 0 outside. So it would probably be spring before I could get to them dig them out and get the tires pulled off.
Thanks Ted, I got your mail.
Stu - Presumably these wheels are the right ones to fit my truck?
Old 01-21-2011, 12:31 PM
ArmyFord's Avatar
ArmyFord
ArmyFord is offline
ArmyFord is starting off with a positive reputation.
I might be interested in the ones 49ford does not take. How much? I would probably pick them up.
Thanks,
Dan
Old 01-21-2011, 12:57 PM
truckdog62563
I've got a pair of the 17.5s presently mounted on an F-3 rear end having the 14" drums. CarlH has a full set mounted on his 49 F-3. But I understand that you're making a big investment decision based on my input, and that I need to be sure I'm giving you straight answers. It would be a good idea for the guys doing the selling to run their part numbers past me before payment and shipment I guess. The part numbers will be on the concave side along the raised curved surface of the drop center. I'll pull one of my wheels and see if I can get a good picture of the number location. I can tell from Ted's pictures that his wheels are the tubeless variety based upon the look of the rim profile. The bolt pattern is another aspect that will not vary. All are 8 lug x 6.5" bolt circle. The center holes will all be the same, and the offset/backspace will be the same as your stock wheels. Also, we can tell from Ted's pictures that the stock hub caps will mount. The wheels have the hub cap nubs on the inner face of the wheel centers rather than on the outer face as later wheels have. So, I'm as sure as I can be that these will work for you. I'll come back later and edit to add a picture of the number location. Stu
Edit - Here are pics of both my wheel numbers as cited in my first post. I'll also add a front view pic of one of my 17.5s to let you compare it to Ted's, and last will be a stock F-3 widowmaker 17". Stu
Last edited by truckdog62563; 01-22-2011 at 04:48 AM. Reason: Reworded third sentence to say it better.
Old 01-21-2011, 01:21 PM
NumberDummy
19.5 = B6D-1015-B
17.5 = B6D-1015-A replaced by B8D-1015-A
Old 01-21-2011, 04:35 PM
fordman75
When I get my rims dug out and the tires pulled I will post more pictures of them and any part #'s I can find on them. But it may be a while.
Old 02-13-2011, 02:23 AM
49truck
49truck is offline
Originally Posted by lance65 View Post
I've got a set of 17.5's of my 59 F250...and I am wanting them gone!
Hi Lance65
Ted (Fordman75) went to a lot of effort to dig out his rims and get the tyres off only to find they aren't in good shape (pin holes etc - Thanks anyway Ted). Do you still have that set of 17.5's that you want rid of?
If so do they match up with the part numbers in this post, how many you got, and how much did you want for them? Could you ship them?
Please let me know as I running out of time to find some wheels for my truck to roll on! My email address is [email protected] if you want to drop me mail.
Thanks
Andrew
  #28
Old 02-13-2011, 05:13 AM
truckdog62563
Andrew - If one of the other guys has only two good ones I'll send you my two to give you a set.
Another option would be the custom wheels that we've seen made by Stockton Wheel. In this attached thread Stockton took original widowmaker centers and put them in new 17" outer rims. The member is very happy with them, and I've got to admit I'm impressed too. Stu
https://www.ford-trucks.com/forums/1...ml#post9905657
  #29
Old 02-13-2011, 05:37 AM
49truck
49truck is offline
Thanks Stu, let's see who comes up with offers of any wheels.
Whilst the Stockton wheels look good I have the issue of getting my windowmakers from the UK to the USA.
  #30
Old 02-13-2011, 05:57 AM
truckdog62563
It wouldn't have to be your widowmakers. One of us over here, and probably close by in California, has widowmakers sitting around that they could donate. Admittedly this scheme would involve a lot of moving parts. Like an old fire truck rally a guy on here tried to coordinate a few years ago! And you'd have to make sure Stockton had their heads screwed on straight to be sure everything came together cleanly. Stu
Quick Reply: Wanted: 19.5" or 17.5" Rims off F-250
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
