codes 13 and 19
Old Mar 8, 2003 | 11:34 AM
chuckles738's Avatar
chuckles738
codes 13 and 19
1989 4.9 Installed the restrictor plate for the egr valve, did not drill the 1/8th in hole in the plate...These are the codes I pulled after installing the plate: Code 13 says: unable to reach lower test limit... Code 19 says; failure in PCM internal voltage... I have no clue on where to go from here or how to repair the problem... The truck runs well, has a lot of power, but am still getting a bit of a rough idle... Any ideas will be appreciated for sure.. Thank you!!!
Old Mar 9, 2003 | 09:47 PM
steve83's Avatar
steve83
codes 13 and 19
Check my code list - I don't think the definitions you're using are accurate.
Old Mar 9, 2003 | 11:24 PM
chuckles738
codes 13 and 19
You are right Steve they are different. I got those codes from auto zone... I don't have a clue of what to do to solve the problem of codes 13 and 19. Will these codes cause a rough idle and what can I do to solve the problem. Thanks a lot for your interest, and i know that your expertise and that of a lot of other guys is greatly appreciated Thank you
Old Mar 9, 2003 | 11:35 PM
steve83's Avatar
steve83
codes 13 and 19
Diagnose the EGR system - the Haynes manual explains it well. If you want it, send me a real e-mail and I'll attach the MityVac manual which explains it very thoroughly, but it's a big document.
