1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Back-up sensor problem
Old 01-21-2011, 08:39 AM
spud57's Avatar
spud57
spud57 is offline
My back-up sensor is coming on all the time when I go into reverse. It does shut off when I press the OFF button.
Not sure where to start trouble shooting but thought best to get any feedback from anyone that has experienced it and the fix. I guess it is either a bad module or a sensor.
Thanks
Scott
Old 01-21-2011, 09:01 AM
acf6's Avatar
acf6
acf6 is offline
This happens to me all the time, I just turn it off while I'm backing up and it has always fixed itself after I turn my truck off and leave it for a little while
Old 01-21-2011, 09:02 AM
scottzj's Avatar
scottzj
scottzj is offline
Hangin 10 bra
Clean it really good, as mine did the same thing. It didnt look like they were dirty but they were, also check the angle its pointing at, cuz if something hit it, then it could be pointing at the ground. Then if its still doing it, unplug each sensor, one at a time and find the one causing the problem. Either replace it or leave it unplugged.
Old 01-21-2011, 09:08 AM
spud57's Avatar
spud57
spud57 is offline
Thanks guys. I gave them a wipe but perhaps some soap and water would be better. If that doesn't help I'll try unplugging one at a time.
I do find them usefull so I do have to get them fixed.
Old 01-21-2011, 10:09 AM
pbeering's Avatar
pbeering
pbeering is offline
Clean the outsides, check for correct alignment, then unplug each one and check for corrosion. Clean as needed and add either dielectric grease or Fluid Film to the connection.
380tom
02-26-2013 10:04 PM
jayc3169
01-08-2013 11:19 AM
ssimpson6
07-04-2010 10:42 AM
MikeDesire
1997-2006 Expedition & Navigator
02-15-2006 08:05 PM
tkj99
06-12-2003 08:20 PM
Quick Reply: Back-up sensor problem
