Water in Fuel Valve
Water in Fuel Valve
2001 7.3 Excursion had hesitation problems when cold. Did a little underhood inspection yesterday and found fuel heater lead was unplugged. Reconnected and decided to also drain bowl for water in fuel valve. Drained for 15 sec. as per direction in manuel. Closed valve and started engine, now valve won't seal closed, not streaming fuel out of drain line but a continues drip. Any ideas how to get this thing to seal or am i going to have to get a replacement part. Any input would be appreciated!!!!!!!!
Yogibear00
Yogibear00
You might and I do mean might can tighten the vavle. This is plastic and cannot be tightened much at all. More likely you need to replace the o-rings. Most of us here have done it at least once. Diesel O-rings is you best source. Fast shipping, good price and great instructions. Link is in my signature.
It's a fairly simply job and you should be able to do it. As far as plugging the fuel bowl heater back up, it may have been unplugged for a reason by the PO and probably not the cause of your cold weather issues. Unplugging the heater usually means it's shorted and will blow the 30amp fuse and prevent starting.
