Boat towing questions
I am looking into getting a bigger boat than my jon boat but i want to know what my limits are with my truck for towing a boat, i know it will be more difficult getting up the wet ramp with heavy a 2wd truck so what i am asking is what would be the max weight you guys think i could get away with at the ramp i dont want to be there doing burnouts at the
ramp and have my boat sitting pretty in the water , i am looking at
a boat that is around 6,000lbs would i be able to get that up the ramp ?
Received 3,102 Likes
on
lots of things come into play when your boat load increases
1) how much longer is the boat gonna be?
2) what condition is the boat ramp in? Gravel? Stone? concrete? black top? rubber? this is all for traction
3) what shape are your tires in?
4) granted 4wd would definitely help
my opinion if you have good tires and the ramps are in good condition for good traction i believe you will be fine... the truck itself wont have any issues pullin. Mainly traction like i say will play a big part
Coalroller got it right, it comes down more to the ramp and the traction then your truck. You should be able to haul 6000 lbs no problem with your truck.. heck double that lol
The big problem is the ramp itself, I am very picky about were I launch my boat and will often drive further for a better ramp. I have never had a problem yet with either the old 75 2wd or the 92 4wd. My boat/trailer combined weight is only 3500 lbs but I have launched it and drug it out of the water with my 3000 lb slide in camper in both trucks. That's a little scary in the 2wd for traction purposes only but the diesel I just lock in the hubs and come up the ramp in 4 low 3rd gear
I had a 22' SunRunner cuddy cabin (no idea on weight) One of the lakes we used to go to had a fairly steep ramp. Problem was not the ramp but the loose gravel and like TJC said, some algae. Even in 4x4 both front and rear tires would slip and spin in the same 15 ft wide area, the full width of the ramp.
If I had the 9.5 ft slide in camper on, it never slipped, the truck would crawl right past the bad spot. I had a 78 Ram Charger with a built 440, 3/4 ton axles and 4:10 gears. That thing spun tires on the same ramp no matter what. Only way to get past the bad spot was to get a run lower on the ramp and keep on the throttle, spinning tires till you got past that bad 15 ft. Then the rangers would come out and want to give a ticket for exhibition driving. GRRRRR!
Tried with 79 F150 with granny. 300. 4wd were broke.
Put in granny it spin at 3 mph until got traction. Boat were 5K lb. Very close to roll back in water if it couldn't get traction.
In my opinion dually with auto isn't good for those. Manual tran would do much better in my opinion.
But I would bring chain that will fit rear tire though rim for emergency it will bite ramp HARD like you have 4wd.
I don't see why you would have a problem pulling that boat with your truck I used to pull a car hauler with total weight around 8k regularly with my 87 F-350 5.8l gas and had no worries. The only time the 4wd should be needed is if you are planning on launching from a unimproved ramp and I don't think it would be wise to launch a 6000lb boat from one anyways. The truck should pull it with no problems unless there is some problem with the trans or something.
alanber
1999 to 2016 Super Duty
08-18-2015 08:46 PM
Duane Drye
11-22-2011 09:08 PM
malibubts
17
02-24-2011 02:20 PM
