Wheels?
Wheels?
i recently put my factory steel wheels back on my truck
it has a few places from rocks that have chips in the paint and rust
i really dont want to take my tires off to have them sand blasted
so my questions are
1) how should i strip the paint (what should i use)
2) what paint and primer
3) what paint would work best for re-pin striping the beauty rings
that is not my wheel but its what mine look like
so my questions are
When I painted rims at my neighbors shop with the tires on here is what I did. 1st mark location of wheel weights on tires. Remove the weights. I used a small handheld sand blasting rig (kinda looked like a garden sprayer) and blasted rust spots. Feather sanded the rest of the rim. I used a piece of sheet metal about 3" wide to form a loop around the rim ontop of the tire. This masked off the tire real easy. Clean rim with a wax/grease remover (Like PPG 320) The used good acrylic primer. Then we just spray bombed them. Reinstall weights after paint dries. As for the trim ring, I just used some straight enamel (or lightly thinned it) and used an artist brush to apply the paint.
BIGskinny
24
06-02-2011 03:09 PM
bigbubba87
03-12-2011 07:04 PM
