2g Alternator S terminals unused?
Curious about two things. My truck does not have charging issues or anything like that, but going down the rabbit hole on alternator-driven tachs is making me as this question-
Section 1 - S terminals:
On most wiring diagrams for a 2g alternator, I see the S wire from the voltage regulator being connected to the S terminal on the connection of doom/B+ output plug. My truck has no provision for an s-wire on the fire plug, and has/had only wires going to the A and I terminals on the voltage regulator. I've never had a problem with charging, although running voltage is lower than I would expect at ~13.x volts. I replaced the ASI plug a few years ago, and just kind of have the S wire dangling/capped.
The questions I would have here is: Why does the S terminal jumper not matter on this truck? Or does it and someone in this truck's life didn't care?
Section 2 - Stator output:
Does the S terminal on the voltage regulator send or receive signal from the stator? I am curious if this would suffice to send signal to a tachometer?
Ah, yes. The Stator output will provide a signal that can be used for a tachhometer. The s terminal on the regulator is not an output.
DIRTYSTEVEN
02-17-2008 10:14 PM
steveneashcraft
12-04-2004 10:19 PM
