97 F250 Front axle swap
I have a 97 F250HD 4x4 extended cab with the 7.3 powerstroke. I plan on keeping the truck for a very long time cause I love it! I am looking to pull the TTB front end out and turn it into a boat anchor and replace it with a Dana 60 and a 2" lift. I understand the king pin versions are better but what year 60s should I look for? Also beside the axle what other components will need to be replaced? Steering box? drive shafts? Any help is appreciated!!!
<!-- / message -->
<!-- / message -->
<!-- controls -->
https://www.ford-trucks.com/forums/9...axle-swap.html If you click on this link and read through the full thread you should get all the info you need.
Good luck.
Good luck.
sarahlou
26
04-18-2009 08:45 PM
