Old Battery, 86 F250, Snowplow, Tired of Charging it up
1986 F250 4x4 manual 302 EFI
Now that my new gas tank and in tank fuel pump are installed, I probably should fork out money for a new battery.
I bought this truck with a plow included in the price. The previous owner put in a marine battery. When I asked him about it he said that the plow pump takes so much juice the regular battery would not be able to keep up.
I've been driving this thing around the farm now for a year & 1/2. I have to keep putting a charger on it.
Today I plowed the lane for the first time this winter. When shut the truck off the battery was dead & it would not restart the truck.
I charged it & got it running again.
I put a meter on it & at idle it is showing about 14.2 volts or so.
When I rev the engine there is no change in voltage.
When I run the snowplow pump, the voltage drops to 12 volts or less.
Was the PO right that marine batteries are best for this stuff.
Or should I just get a stock battery?
Marine batteries are not the best for starting and quick high amp draws like your plow. They are for long term slow drains, with some capacity for starting. A regular battery is made for starting and short high amp draws and would be better for your application. Get the biggest one they sell.
on
I run a never start battery from wal mart and I do commercial plowing with mine, stock alternator. No problems when everythings working. If anything I'd like to upgrade the charging system... A bigger/better battery will discharge eventually with the stock alternator if you are using more than the alt can replentish.
I only plow for myself, about a 1/4 mile lane & around the property.
Last year we had a big snow & midway busting through the drifts, I stalled out.
I had to pull a good battery out of something else, load it on my kids plastic sled & wade through 4' snow to the front of the truck to jump start.
ArdWrknTrk,
If I did this for money, I'd take your advice, but I mostly plow so my wife can get the heck out...
Oh, Hi Honey
ArdWrknTrk,
Oh, Hi Honey
on
Like Franklin said, get the biggest battery they sell and you shouldnt have any problems if your alt is working properly. If you are in a spot where you need to constantly lift and angle the plow for a long time of course thats the biggest strain on the battery, but I do a lot of cul-de-sacs and Mine works fine.
You can get an alternator from another Ford product with electric fans for $25 at any junkyard.
Maybe an hour (or two) to swap.
How much is it worth to you NOT have to go through this wading through 4' of snow with the kid's sled again ?
I think your best option is an alternator upgrade.
THIS HAVING BEEN SAID ... if your alternator output falls WAY short of providing the electrical power you need to operate your plow ... it will NEVER have enough output to re-charge the battery (ANY BATTERY) sufficiently for the next starter operation.
You could buy the biggest battery available ... but it could be like needing more water out of your well ... and you try to fix it by digging a bigger hole ... when the source of the water is not sufficient to meet your need.
Meaning you are probably gonna have to keep charging your battery ... unless you replace your alternator with one having sufficient output to do a better job of meeting your electrical needs AND charging your battery at the same time.
Without seeing the amp rating of your plow motor I would guess that you need an alternator with a MINIMUM of 100 to 150 amp output to keep up with the demands you are placing on it.
For more information go here:
http://new.plowsite.com/showthread.php?t=54628
Or do a google search of the words "snow plow alternator size"
on
In my previos post I said my stock alt kept up fine with the load of the plow but I didnt notice you have a FI truck wich uses more electricity than mine. I believe a 100amp alt would be plenty for EFI and a plow, my 70amp alt is enough for my carbed truck. I also run a 12v salt spreader. A friend got this: JEGS 1-Wire Ford Alternators - JEGS and hasnt had any problems with it.
Something else you could do is add an aftermarket voltmeter, monitor it while plowing and if it gets low run the truck at fast idle to recharge it.
