Ive been having this problem for a few weeks. The truck is a '79 F150 w/ 351m and C6. Ive tried adjusting the dashpot, idle speed, and idle mixture to no avail. Im reading around 20-21hg in neutral and 16-18 in drive-not really sure how good those are. Timing is set to spec, emissions components are intact; although I did pull the cat off, take the insides out, and put it back on. On a possibly related note, Ive been experiencing hard downshifts on occasion. I pulled the vacuum line off the vacuum mod and theres no sign on trans fluid. Any help?
Can I get a little more detail on what's exactly happening
Upon letting my foot off the gas, the engine rpm drops and the vacuum drops down close to 10hg. It sounds like its gonna die but then starts back running good again. It only does it at lower speeds, maybe only in first gear, although Im not 100% sure.
I had the same type of thing with my 351w. Lettin off the gas it would stumble and shake. Turns out the air/fuel mixture screw on one side wasn't working. Replaced the carb and it all went away
Hmm, so I went to Advance Auto to get some Sea Foam and talked to the parts guy while I was there. He suggested replacing the trans. modulator and maybe finding a new dashpot. I just orderd a new modulator so Ill put that in tomorrow and see what it does.
Replaced the trans mod, started driving down the street, had to turn around. Took the carb off a blew out all the passages. Runs better now but still stumbling. Adjusted the dashpot almost all the way out a while ago; ill see what that does in the morning. If that doesnt change anything, its probably gone and Rockauto has them for $10.
check float level in carb to high could cause that good luck,
I just checked it yesterday, was 16/32. I just noticed something that I hadnt noticed before, a ticking noise coming from the right valve cover could these two things be related? Sticky lifter? Bent pushrod? Burned valve??
