Bedliner????
Old Jan 11, 2011 | 08:14 PM
ford reiner's Avatar
ford reiner
Bedliner????
Suggestions for bedliner for shortbed with tailgate step and gooseneck hitch.
Old Jan 11, 2011 | 08:37 PM
widerider98's Avatar
widerider98
I have a 2011 f 250 with 8 ft and tailgate step. couple weeks ago I had Rhino put in, $399 plus tax. Worked great, install was good, looks good.
Old Jan 11, 2011 | 08:38 PM
marchare011's Avatar
marchare011
Post
Welcome to FTE.
I don't have any bed protection yet. Still serchin the web, and this forum.
Old Jan 11, 2011 | 09:14 PM
Marauder92V's Avatar
Marauder92V
The three spray in options are: factory done, Line-X and Rhino. I have the factory spray option and it looks great and solid. On my Diamondback cover, it has Line-X. It shines more than the bed liner but looks very robust.
As for liner mats, I will let people who have them provide their insight.
I did have a slide in liner on my 1986 F150 and it did trap water underneath which caused some rusting.
Hope this helps.
Old Jan 11, 2011 | 10:07 PM
porthole's Avatar
porthole
You can almost always get at least a $25 coupon on the Rhino website.
Old Jan 12, 2011 | 06:19 AM
golfmedik's Avatar
golfmedik
I have both Rhino and Line-X. The '10 F350 has line-x, which is thinner than the coating on my 01 Silverado 3500 that has the Rhino. The Rhino has held up well but has started to fade(which I believe they all will). I think you would be happy with either one.
Old Jan 12, 2011 | 09:15 AM
cford716's Avatar
cford716
There have been other threads on this. Between the factory, Line-X, and Rhino I don't think you can go wrong. If I remember correctly there was some discussion on the installers so you may want to see some of their work. But for the product if installed correctly, it just comes down to who is in your area. Of course if you already have your truck that takes care of the factory option.
Also, in my opinion stay away from the drop-in plastic type. Someone else will have to comment on Bedrugs, I have never seen or had one.
P.S. There was a new brand of spray-in that was also discussed recently but I don't recall the name.
Old Jan 12, 2011 | 10:01 AM
Jigger2020's Avatar
Jigger2020
Line-ex in mine, no sliding around, just my .02
Old Jan 12, 2011 | 10:04 AM
hanklin's Avatar
hanklin
line-x here and love it
Old Jan 12, 2011 | 10:32 AM
widerider98
I have a 2011, put in rhino, rubber mat, and bakflip. Makes a great set up so far.
Old Jan 12, 2011 | 02:15 PM
Hu Slung Pu's Avatar
Hu Slung Pu
I had the Ford drop-in liner in my F-150. I hated it, as everything slipped around in the bed. My new F-250 has the factory spray-in liner. No slipping, very nicely done and I love it. I'd go with a spray-in like Rhino or Line-X.
Old Jan 12, 2011 | 02:41 PM
widerider98
You put a 50 buck rubber mat from tractor supply on that and you got it all!!
Old Jan 12, 2011 | 06:12 PM
User 72324's Avatar
User 72324
I had Line-X installed and so far it's great. Things stay put, it holds up to abuse quite well.
Old Jan 12, 2011 | 06:42 PM
TheKid1's Avatar
TheKid1
Bed Rug on my 09 f150. Nothing slides, great on the old knees, washable, oil resistant
Nuff said
Old Jan 12, 2011 | 07:15 PM
elemakule's Avatar
elemakule
I have a new F250 but I've already had the fifth wheel installed. Can they spray in Rhino with the rails in or do they have to be removed?
