96 F350 460 Air Charge Sensor
Old 01-10-2011, 10:54 PM
JR_F350's Avatar
JR_F350
JR_F350 is offline
3 questions. Where is teh Air Charge Sensor on a 96 F350 460? What should the input voltage on it be? and what is the input voltage source?
Help!
Old 01-11-2011, 07:26 AM
subford's Avatar
subford
subford is offline
I take it you are talking about the IAT sensor and not the MAF sensor that is at the RH front of engine compartment.
Here is the location of the IAT sensor on a 1996 California 7.5L engine in a F350.
5 Volts DC.
Pin #96 of the PCM Computer
Old 01-11-2011, 09:34 AM
JR_F350's Avatar
JR_F350
JR_F350 is offline
Thanks! I had the ICT and ECT mixed up. Do you know the input voltage and power source for the ECT?
Old 01-11-2011, 10:03 AM
subford's Avatar
subford
subford is offline
The same as the IAT above, 5 volts & pin #96.
Old 01-11-2011, 10:45 AM
JR_F350's Avatar
JR_F350
JR_F350 is offline
Thanks again. So on the ECT I got .7 volts o the input side with a warm engine. The only convenient ground I had was the battery ground. return voltage was all of 0.02 volts. Is there a better way to measure the input and return voltages? Right now I have metal pins stuck into the wiring harness at the sensor end.
I'm getting lean engine codes and have gone through all the usual stuff like MAF, fuel filter, vacuum leaks, fuel pressure regulator, etc. and am suspecting that something is not sending the PCM good data.
Old 01-11-2011, 11:19 AM
subford's Avatar
subford
subford is offline
If you are getting errors on all of those sensors of to high voltage I would say you lost the ground to, in or from the computer.
The ground return at each sensor should be the same electrically as the NEG post of the battery.
Old 03-31-2011, 08:39 PM
Westernksford's Avatar
Westernksford
Westernksford is offline
subford:
I have a 1988 E350 with a 460 and have located what I believe is the Air Charge Sensor in approimately the same location a shown in the diagram for the 1996.
Do you have any information regarding a 1988 ford?
Old 03-31-2011, 10:16 PM
subford's Avatar
subford
subford is offline
Yes I do.
What is it you want?
Old 04-01-2011, 06:28 AM
Westernksford
I was wanting a diagram for a 1988 ford 460, to verify the location of the ACT sensor before I start working on the engine.
Old 04-01-2011, 08:02 AM
subford's Avatar
subford
subford is offline
They did not put a engine diagram in the 88 EV&TS manual but here is one from the 1990 EV&TS manual, it should be the same as the 88. There may be one in the 88 or 89 shop manual that I can scan in if this is not what you want but I will have to find where I put them first.
ACT sensor at location F-6 in the diagram:
Old 04-01-2011, 08:46 AM
Westernksford
This is excellent and what I wanted.
Thanks for the Help.
camarokid81
15
10-27-2021 08:24 PM
maltondhc
08-18-2016 08:28 PM
Cletus98
18
08-15-2016 11:39 AM
Bigjoe31
01-30-2016 06:14 PM
clintusaf
06-24-2015 10:43 PM
Quick Reply: 96 F350 460 Air Charge Sensor
