#8 cylinder misfiring - Ford Truck Enthusiasts Forums
Old 01-10-2011, 09:28 PM
charlottehall
charlottehall is offline
charlottehall is starting off with a positive reputation.
went to change plugg for first time after buying.......all went well till i got to #8..whoever put it in last broke it so the top half of the plug came out and left the bottom half in...had to order special plug removing tool...finally got it out.....now its misfiring in that same cylinder!!!! changed the coil and nothing happened!!!??? its really bad shaking all over not ideling well and even dies while in gear if not giving gas??? what next???
Old 01-10-2011, 09:36 PM
1bad67sbf's Avatar
1bad67sbf
1bad67sbf is offline
1bad67sbf is starting off with a positive reputation.
remove the new plug and look. it was not the last person to install the plug it was the plugs are a joke and break easy.
Old 01-10-2011, 11:07 PM
charlottehall
and look at what???
Old 01-10-2011, 11:09 PM
charlottehall
the plugs are good now we put new ones in....now its misfiring and engine light is still on
Old 01-11-2011, 05:22 AM
FORDTRKSTER
FORDTRKSTER is offline
FORDTRKSTER is starting off with a positive reputation.
Very possible it could be a bad injector , there is a recall on the injectors .Google ford fuel injectors.
Old 01-11-2011, 06:07 AM
1bad67sbf's Avatar
1bad67sbf
look at the new plug. just because its new does not mean its good. see if its black or if you cracked it when installing. could be an injector but i thought they throw more codes than just a single cylinder misfire. they screw with the o2 readings. before i go to far with injectors i would pull the plug since its new it should not break
Old 01-11-2011, 11:54 AM
charlottehall
ya we pulled the plug last night and it looked fine.....idk
cottonf150
1997 - 2003 F150
02-02-2015 09:53 PM
Went724
1999 to 2016 Super Duty
09-10-2014 05:53 AM
trucktech
Modular V10 (6.8l)
05-30-2011 08:34 AM
Lariatpower04
2004 - 2008 F150
08-28-2010 12:02 AM
88 Bronco
Ranger & B-Series
21
12-22-2009 11:46 AM
Quick Reply: #8 cylinder misfiring
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
