Replaced the distibutor, now no oil pressure
Saturday I replaced the distributor in my 1993 4.9 F150. More difficult than expected because of it being such a tight fit (both old and new). Removed all plugs, found TDC, and set the distributor pointed to #1 cylinder. Reconnected everything, verified the firing order. Started right up, but the oil pressure gauge shows no pressure. Shut the truck down immediately.
The sending unit is very close to the distributor and I certainly could have bumped it during the distributor install. I tried to check for voltage from it with a voltmeter yesterday and the voltmeter always read 0.0.
If I ground the wire to the sender and it pegs high, is that a valid test on the gauge? If that works, what is the best way to test the sending unit before I replace it?
And, is there a way to convert this over to a real gauge instead of the "idiot light" version?
Do not start it again until you get a proper answer to this. I don`t know enough about the 300 six to be sure but the oil pump may be driven by a shaft that engages in the distributer shaft. When the new dist went in the oil pump drive shaft may not be engaged so the oil pump may not be driven at all.
Like I say I don`t know, so hopefully someone who does will reply soon. Or maybe do a search and see what comes up.
on
on
OK, so here is the plan.
1. Ground the wire that attaches to the oil pressure sensor. If the needle does not move, the gauge is bad, replace the gauge, DONE. If the needle moves (roughly to halfway), the gauge is fine.
2. Remove sending unit. Cycle the engine with the solenoid and watch for oil to come out of the hole. If it does, replace the sending unit. If not, remove the distributor and check that the shaft is engaged.
If you're lucky, we used to use a piece of fuel line that fit over the oil pump drive and spin it with a drill too.
Make sure the shaft DOES have all the flat sides on it and the dist hole isn't spun rounded. Can it go in both ways?
Then again, if oil shoots out when you crank it, might be ok too?
I haven't looked at mine but I'd almost bet any parts store has a real gauge, or even a hrdware store for a few bucks, just screw it into the sending unit hole just to see..or get a pipe fitting tee and run them both, gauge under the hood and stock dash gauge for backup.
Heck, I may even look into that just for fun and minor bragging rights.
Give me something else to look at when I have to hood open.
I just dont like the thin plastic tubing I've seen with oil gauges running near hot stuff and chafing in 10 different places.
