Reg cab to Ex cab conversion?
I have a 1986 f250 hd 1 ton rear end i ve changed all the body parts but the cab which has been in a wreck be 4 i got can tell by the bondo and cab warpage i know there is a diffrece in the frames but i have 3in body lift tell me what u think its long wb so im sure i can put a swb bed with it
You will have to rig the body mounts like you mentioned to clear the kick-up on the regular cab frame. When it's all said and done, I don't know if the bed will line up correctly with the cab and the rear wheel or not. I think the extended cab trucks had a different wheel base, so you might have to make a custom flatbed to make it all work out.
on
The frame layout is quite a bit different between a regular cab long bed and an extended cab short bed. Between a reg cab and ex cab, there is 22" more frame between the cab mounts, between the rear of the transmission crossmember and before the frame kicks up to the rear cab mounts.
Where you can see the weld on the frame here:
There used to be another 22" there, I shortened the ex cab chassis to fit a reg cab.
Now for bed legnth, the 16" difference in wheelbase is found between the front set of bed bolts and the front hangar for the rear springs.
So, even if you do overcome the obstacle of getting the cab to sit properly on the frame(I have seen a crew cab on a reg cab chassis with a sectioned rear floor to clear the frame before) You are going to have to cut 6" out of the bed.
This is a doable project, but, far from any sort of a bolt on deal.
AppocAlexx
12-27-2016 11:38 AM
