RHD IDLER BOX DELETE
Hello everyone, I was just wondering if anyone had ever deleted to idler steering box and run the steering arm from the right box to the left knuckle. It is an Australian delivered 2004 7.3l F250 super duty. I need to remove it to make room for new brackets and so on. Thanks heaps
Hi Jason. Pretty quiet around here.
I'm just curious what you are aiming for?
The idler steering box is the left hand box?
I'll have to have a climb under mine to get an idea of where you want to run the steering arm.
What brackets are you installing?
Are you local?
Sorry for all the questions, cheers Wayne.
Are you local?
Hey buddy, yeah she is like a host town hahaha. So I would like to get rid of the L/H Drive steering box. Okay so the full story is a bought a wrecked f250 and now I'm putting a HJ47 landcruiser body on it. Now to get everything to line up again I had to move the axle forward 100mm in doing this the panhard rod mounts don't line up and I have clearance issues in the engine cross member...... So I need to delete that box to make a new mount and mod the crossmember. Yes it is a massive can of worms lol.
Umm car is in Geebung QLD
Cheers Jason
Cheers Jason
https://www.ford-trucks.com/forums/1...ing-boxes.html
this kit changes the panhard bar to the other side. As I said it mounts of the front diff and is fixed to the frame under the drivers side
What Brian said.
This is the mob: Home | Rocket Sports Trucks
Your build would be interesting - It's a narrow body to put on a wide frame and axles!
BigBlueCat
06-07-2016 06:34 PM
59flatbedford
04-11-2007 07:30 PM
