Remove my hub!!! and rotor on 1990 f150
thanks everyone for your help.
The hub and rotor definitely spin.
So all i have to do is pull insanely hard? or hammer it?
btw i'm throwing the rotor away because its grinded down from my wheel falling off while driving
a have a dust cover or whatever you call it on the back and i dont know how to take that off so there is only a little portion (where the caliper was) where i can hit it with a hammer.
I would get between the knuckle and the rotor with a pry bar and try to pop that thing off there then. Sounds like there is some major damage going on in there to me. I am wondering what the rear bearing looks like.
You said it moves forward a little then stops? Maybe about 1/2 a inch? I might be willing to bet the rear bearing is stuck on the spindle and once it comes to the rear seal the hub stops moving. As I said get in there with a pry bar and pop it off. If that what's happening you will need to pry and get the rear seal to pop out / out of the Hub, and the hub and rotor will fall right off.
The fact that the wheel spins means the bearing isn't frozen and moves in the race. The only thing that's holding the rotor on the spindle is the grease seal. The inner bearing is not removable until after the rotor comes off but there is absolutely nothing else in the way. Once that outer bearing comes out there's just nothing else there.
Pull harder.
Pull harder.
The outer wheel bearing cone should come out after the roller assembly that is shown in your picture.
Looks like it might still be in the rotor, try to move it with a screwdriver or a cold chiesel then when it's in the correct position the hub should slide off with the outer bearing cone.
There should be inner cone, roller assembly and grease seal in the rotor on the inside portion.
#30
